Question about Miele Novotronic Premier 500 Front Load Washer
Miele washing machine; dashes appear in display and washer will not work
The buzzer sounds and "---" appears in display panel; washer will not start
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
Master_Tech
  • 770 Answers
SOURCE: miele w1113 alarm buzzer
do you have 3 dashes across the dispaly?? you need to get into service mode to access the fault
Posted on Aug 20, 2008
  • 297 Answers
SOURCE: red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Posted on Apr 16, 2009
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
On and off switch has Been pushed in slightly but still works Miele W3623 wash machine. Is it possible buy a new switch
replace the whole display panel or can buy the switch
Tony, It looks like Miele wants whole panel replaced on the washer.
Miele Customer Support Product Manuals Brochures
Mar 31, 2016 | Miele Washing Machines
Start button light flashing will not start
Hi dear.
You need to contact Miele to assist your machine repair. Description as blow. Thanks.
Start LED flashes rapidly
The drain pump (M8) is activated, level-controlled, for up to 1 h.The buzzer sounds intermittently for 2 min irrespective of its setting.Digital display: - - -
Cause
Technical fault.
Feb 01, 2016 | Miele Washing Machines
Miele W1203 washer, buzzer sound with no indicator flash. how can i fix it
It sounds as if there is a leak and water in the pan (bottom of the machine) the front of the machine would have to be removed to check and determine the cause of the leak
Aug 02, 2014 | Miele Washing Machines
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
CODE E4 ELECTROLUX EWT64S FULLY AUTOMATIC WASHING MACHINE
In my experience, E4 is appear when spin is starting. Then I check the 'magnetic door safety switch' and gotcha, I find the problem --> 'magnetic door safety switch' is damage (always open). Because some reason, I am short-circuit it. Fixed.
Oct 11, 2012 | Washing Machines
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Jun 20, 2011 | Miele W435WPS Front Load Washer
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Feb 15, 2011 | Miele W 4800 Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele w1113 alarm buzzer
Aug 17, 2008 | Miele Touchtronic W1113 Washing Machine
Miele Novotronic Premier 500 Front Load Washer Logo
150 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
