Mac-buffalo ministation is on read only mode
Can anyone help me change the setting! thanks
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
SOURCE: cannot access data in my buffalo ministation orange light showing
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
Posted on Jul 07, 2009
bob_computer
  • 3153 Answers
SOURCE: xp cannot install this hardware. Buffalo
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Sep 24, 2009
Testimonial: "very helpful advice and correct also. I had changed the usb lead and it cured the problem."
SOURCE: i have a buffalo ministation 500gb,now its not
i had the same issue. the light keeps yellow and the computer jams. ive just submitted a request for Buffalo. it seems those HD live for 6 months only.....
Posted on Apr 22, 2010
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
My buffalo hd pntu3 hard disk is encrypted using the default software from drivenavigator , securelock easy manager. how to remove the encryption?
In the software Secure Lock Manager Easy is a tab "Setting the Encryption mode" Pressing "Releasing encryption mode" will remove the encryption. Make a backup of the data before please.
Nov 03, 2013 | Buffalo Technology Buffalo MiniStation...
I want to change permissions. It is read only
Boot your computer into safe mode then open mycomputer right click on the drive and click properties you can change the permissions from there
Oct 14, 2013 | Buffalo Technology MiniStation Stealth 1TB...
Buffalo ministation
Are you doing this as an administrator On the ''Security" tab, towards the bottom click on "Advanced" then "Change Permission" and go from there. Should be able to affect all sub folders and whatnot.
Thanks
Oct 14, 2013 | Computers & Internet
How to format buffalo ministation hdd in mac
Watch this video, select FAT file system if you want to use the drive in MAC and Windows
Feb 02, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
My portable drive is not recognised many times
The format of your drive is probably not correct. If data is not stored on your hard-drive, format it to NTFS if on Windows, or Mac OS Extended (Journaled) if on a Mac. If there is data, back it up to a computer that can read it and then format the drive.
May 31, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
Computers & Internet Logo
David Payne
David Payne
