Question about LG LRSC26944 Side by Side Refrigerator
Lg side by side won't freeze but motor is running
Changed thermostst and heater hose, car ran fine but leaked on right side of engine (Freeze Plug) now car stopped running while driving and wont start
sounds like the frost plug(freeze plug)let go and needs to be replaced. may have overheated the motor and it stopped due to overheating, as you say it was running and then just stopped and won`t start. just so you know the right side of the motor is the side facing the radiator as the pulleys face the drivers side. this is how a tech differentiates left from right on a Honda. fill with the proper anti-freeze and water mixture. this is all the help I can give you with the information you have supplied.
Jan 31, 2014 | 1992 Honda Accord
My LG LSC 26905TT Refrigerator started to heat up around the outside of the freezer side/top and center bar between the fridge and freezer. The freezer is not freezing no matter how high we set it or the...
HI.IF THE REFRIGERATO BOX OR DIVIDER IS HOT ,CHECK THE CONDENSER MOTOR ,FOR RESISTANCE OR CONTINUITY,CHECK FOR POWER COMMING TO CONDENC MOTOR,, IS OK REPLACE THE CONTROL BOARD OR REPLACE BOTH..GOOD LUCK..
Jul 04, 2011 | LG LSC26905TT Side by Side Refrigerator
Lg fridge freezing food in freezer section
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for
the cold control and the air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Hope this helping solving the problem.....
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
My fridge is freezing food in the fridge section. The eggs closest to the freezer are all frozen, vegetables are frozen.
the cold control and air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this help in solving the problem....................
ERIF code no ice or water dispencing Is this an internal fan fault ? whats the fix?
Replace the evaporator fan motor.
Part#4681JB1017D
You may also need the main computer. Usually it is the fan motor.
Jan 08, 2010 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Freezer not freezing, fridge is about 50 degrres in my lg side by
Check the relay on the compressor. But in order to due this right you are really going to need to have a company replace yor condensing coils and your drain pan. Check also the thermostats. Located under the dials to adjust your temperature settings. You can get some of the parts at repairclinic.com
Feb 22, 2009 | Refrigerators
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
LG LRSC26944 Side by Side Refrigerator Logo
16 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
