Question about GPS
What does tcu diag code 03117-00 mean on a Man truck
2 Suggested Answers
ogdad22363529
  • 313 Answers
SOURCE: How can right front axle air pressure control module of MAN truck affect AUTO gear selection failure?
maybe the relays control 2 items not just one.need wireing book for that to see if others are on the same circuts
Posted on Apr 20, 2016
Tcu 3117 man
RE: MAN TCU DIAGNOSIS 03117-00 tcu code 3117 means clutch self adjustment which is between 3 common brothers( pressure plate..release bearing and clutch ) but before you decide to change any check the pressure system from the air drier valve into the actuator if its ok
concerning the pressure leakage around the gearbox indicates there is a problem with the zf astronic...sometime even the automatic transmission fluid may also leak its the zf astronic replace or repair if necessary
in addition actuator problem will come up with tcu fault code 3198-08 on the screen
Apr 12, 2017 | Miscellaneous
Man tga what is tcu
TCU stands for Transmission Control Unit.
Apr 12, 2017 | Toys
Apr 20, 2016 | Cars & Trucks
I have a honda accord 1992 ex coupe 2 door. Sometimes when engine is hot the check engine light flash solid and d4 is blinking that cause me not to start the car i have to wait unitl check engine ligth...
Check around the ecu and a tcu for moisture. Others have reported similar issues and find the carpet very damp. Some have pulled the control modules to dry out and let carpet dry and the issue was resolved. Of course, if theRe is moisture then you need to fix that leak, and the damage could be too bad to fix by letting it dry.
Apr 07, 2017 | 1992 Honda Accord Coupe
What is the TCU/TCM code 7 mean?
Automatic Transmission Control Unit (also known as the automatic transmission computer or TCU/TCM). I am giving you this link so that you may read what may be the problem of your car.
Follow this link: http://techauto.awardspace.com/transmission.html
Jan 11, 2011 | 1991 Honda Accord
2000 hyundai accent with error codes p0717 and p1529
P0717 - Input/Turbine Speed Sensor "A" Circuit No Signal
P1529 - Customer Snap Shot Request
  • NOTE_P1529 is a generic code which is issued by the TCU to tell the ECU to turn on the CEL. It means nothing by itself and is usually included with other TCU codes.
Aug 21, 2010 | 2000 Hyundai Accent
Transmission stuck in forth gear check engine light is on.
Your TCU (transmission Control Unit) is bad. it is located behind the passenger side kick panel. you can purchase it on ebay for about 79.00 with exchange.
Lugnut61
Feb 08, 2009 | 1992 Honda Accord
GPS Logo
754 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
