Question about Water Heaters
Heater manual hi tech wbr 3.8 h-b - Water Heaters
Reset bosch error code
reading the manual would be my first choice .but try Google and see if there might be one available . I don't use hi tech appliances as they seem to fail more than the old manual type units
May 23, 2015 | Bosch Water Heaters
Why wont takagi tk jr doesnt heat
Flowmeter.....Gas Pressure.....Ignition?
I'm not psychic.
Tk-Jr is a dependable 140-145,000 BTU 2nd Gen Unit SS Vent , <.82 EF.
Failure is a Tech Service issue and the Tech may need Factory Support from California. This is probably a pre-A.O. Smith/Takagi unit
Does the igniter spark 3 times than shut down and fan purge HE? Can you smell gas tracer (remember NG/LP is odorless w/o mercapthan in it)? Tech will need a digital Manometer for Line and Manifold Pressure Test. And a Multi-Meter Toll Free # on Unit or in Manual
Sep 07, 2014 | RTO Takagi Jr. TK-JR-N Tankless Water...
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
Rtg74pvn2 rheem tankless water heater gas problem
1) You want the truth: Forget tankless.
There are many tankless water heaters with insoluble problems.
And endless problems.
Rheem knows it.
2) Do you really expect your home computer to work flawless after replacing motherboard?
Get your money back from Rheem, or get a full replacement.
3) OR fix water heater yourself today: Install tank-type gas water heater for $350 from local box store.
FYI: Do not buy Rheem, Richmond, Ruud, GE as these units from Rheem have problems that require service technicians.
Instead buy Whirlpool, American, State, Craftmaster, Reliance, Kenmore, as these units from AO Smith have fewer problems and can be repaired by homeowner using simple part replacement.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
4) Copy following link for troubleshoot resources, and possible manual for Rheem, Richmond, Paloma water heaters:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 16, 2012 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
4) Information on anode rods
http://waterheatertimer.org/Replace-anode-rod.html
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
Hi, I have a Bosch tf 400 ng 1tr, about 7 years old, just today it started producing only 1/2 the heat. Any suggestions ( I have gas experience on cookers and stoves) so I should be able to fix if I'm...
You ask for free nudge:
I have links for resourceful do-it-yourselfer since tankless is large and developing field that can take years of study.
For example tankless are prone to lime build-up and must be de-limed each year. Search utube for 'delime tankless' to help restore efficiency.
Best place to start is troubleshoot section in your product manual.
1) BOSCH website is easy to navigate:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
2) Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
3) Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
4) Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
5) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/pro-n-con.html
6) Add a comment for more free help.
Mar 14, 2011 | Bosch Water Heaters
Will not stay lit.
You posted under Bosch tankless water heater.
Fixya is ready to assist resourceful do-it-yourselfer, so read information below, and if you are unable to determine what problem is, post another question saying what you've done so far, or contact service technician and when technician arrives, ask that person tricks and tips for maintaining your tankless water heater.
1) Best place to start is troubleshoot section of manual.
Bosch manuals:
2) Open pdf of typical manual: troubleshoot section page 33.
http://www.boschhotwater.com/Portals/7/TechManuals/2400E_English_12_2007.pdf
http://www.boschhotwater.com/Portals/7/TechManuals/250SX_English.pdf
3) BOSCH error codes
5) Bosch problems at Fixya:
6) Read manual cover to cover
and make sure maintenance is scheduled.
For example de-liming is recommended each year.
Utube search de-lime tankless water heater
7) Install DIY tank-type gas water heater and avoid the whole headache
Mar 10, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Have Error code FO, no hot water. Press reset and water gets warm for few seconds then goes off again.
1) BOSCH website shows error codes.
FO does not appear:
2) I do not see FO error code listed on Internet search
Other FO questions at fixya seem to have no answer:
http://www.fixya.com/tags/error_f0_bosch
3) At this point, I would suggest calling a service technician.
While waiting for service, read manual cover to cover several times.
4) Your manual is valuable resource, and shows the word 'maintenance' and 'troubleshoot' frequently.
Tankless are maintenance heavy, and should be de-limed each year.
U-tube search "delime tankless water heater."
5) Also explore Bosch website for your manual and other valuable information.
6) When service tech arrives, ask that person for tips and tricks about your unit that will help you maintain your water heater.
7) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache.
Mar 08, 2011 | Bosch Water Heaters
Makes low rumble noise when 2 or more faucets running hot water. New installation. Inlet vent: 3 feet with 3 Ls. Outlet vent 3 ft with 1 L. Gas: 3/4" all the way(no flex).
CALL BOSCH TECH SUPPORT, THE NUMBER IS BEHIND THE COVER, THERE ARE A SERIES OF DIP SWITCHES FOR THIS WATER HEATER THAT HAVE TO BE SET ACCORDING TO YOUR ELEVATION, VENT LENGTH, AND USAGE. THIS IS FIVE MINUTE FIX.
Nov 19, 2009 | Bosch AquaStar 2400ES-LP
Water Heaters Logo
22 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
