Question about TurboChef TORNADO Electric Oven
Will not load new menu
Turbochef oven will not load new menu from card. After I enter pin and 9, it does not bring up the load menu screen
4 Suggested Answers
  • 7 Answers
SOURCE: about my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
Posted on Nov 17, 2008
  • 15 Answers
SOURCE: TURBOCHEF C3 AND TORNADO
to change temperature press up and down arrow keys simultaneously when asked for pin press 9 then the enter key you can now change temperature in 25 degree f increments by using up and down arrows temperature range is 350f to 525f once you have set the temp you want press enter button to set the temperature as the default. To change menu settings is a little more complicated but not to difficult
Posted on Apr 29, 2010
Sagar Tech
  • 107 Answers
SOURCE: I have an Turbochef NGC
BEFORE WORKING ON OVEN MAKE SURE YOU TURN IT OFF AND DISCHARGE CAPACITOR.IF YOU DON'T KNOW THEN STOP HERE AND CALL TECHNICIAN.
If you know how to use multimeter than check the resistance of Convenctional heater and the IR element.
CC heater .....not sure how many ohms
IR should be 14 ohms
If both are in specification then replace breaker(thermostat in the oven).
Usually if breaker trips 4-5 times then its good to replace it.
reply me if you need more help
and don't forget to vote me.
Posted on Aug 26, 2011
How to find error codes
press the back key twice.
press back + enter at the same time.
type 9-4-2-8 (text the word "what")
then enter
press the faults soft key.
Mar 23, 2013 | TurboChef TORNADO Electric Oven
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
I have a turbochef tornado and the panel wont light up at all, or oven start. when i turn the power on, all i can hear is a very faint mmmmm or whirr for a second then nothing, and nothing comes up on the...
you may need to change the I/O board usually around 420 to replace. once you take the top and right cover off look at the I/O board the connector at the bottom is for the keypad sometimes this comes loose and can cause the keypad to not work correctly.
enter test mode
when the oven is off press back and enter at the same time then type in pin 9428 then press enter
select self test and follow on screen directions
hopefully this will give you some insight as to what is wrong
if you have any problems entering test mode and you have checked the connector and the bottom of the I/O board just replace the I/O board
Dec 11, 2009 | TurboChef TORNADO Electric Oven
I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Dipending upon what kind pizza you want to use.
Subway using the same toster to Bake personal pizza (90 Second for 1 and 120 sec for 2 pizza
Oct 17, 2009 | TurboChef TORNADO Electric Oven
what setting. the code to get into diagnostic area is 9428.
Nov 22, 2008 | TurboChef TORNADO Electric Oven
About my turbochef toster oven it has f8 low heat problem
Nov 15, 2008 | TurboChef TORNADO Electric Oven
My turbo chef oven
The wave guide cover is a simple fix the problem being that after it is replaced you should have a leak check performed I dont know if you have a source to rent a refractomemter to perform this test. Most honest service companies will have a ref meter to check for rad leakage.
Nov 10, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
27 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
