Question about LG WM-2277HW Front Load Washer
Lg error code 3p - LG WM-2277HW Front Load Washer
Thermostat Part Number K36P1344 202569 02-07-3P
no but the threshold switching temperature must be correct
Jul 16, 2014 | Heating & Cooling
How to check the resistance on the iac in a 2000 acura ti?
Here you go: 2000 3.2TL - DTC Troubleshooting: P1519 (14)
DTC P1519: IAC Valve Circuit Malfunction
  1. Reset the PCM.
  2. Turn the ignition switch ON (II).
    Is DTC P1519 indicated? YES -
    Go to step 3.
    NO -
    Intermittent failure, system is OK at this time. Check for poor connections or loose wires at the IAC valve and the PCM.n
  1. Turn the ignition switch OFF.
  2. Disconnect the IAC valve 3P connector.
  3. Turn the ignition switch ON (II).
  1. Measure voltage between IAC valve 3P connector terminal No. 2 and body ground.
    Is there battery voltage? YES -
    Go to step 7.
    NO -
    Repair open in the wire between the IAC valve and the PGM-FI main relay.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s80wa32k72100091519faad01
  1. Check for continuity between body ground and IAC valve 3P connector terminal No. 1.
    Is there continuity? YES -
    Go to step 9.
    NO -
    Repair open in the wire between the IAC valve and G101.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s80wa32k72100091519faad02
  1. Disconnect PCM connector B (25P).
  1. Check for continuity between body ground and PCM connector terminal B23.
    Repair short in the wire between the IAC valve and the PCM (B23).n
    NO -
    Go to step 11.
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad01
  1. Connect IAC valve 3P connector terminal No. 3 to body ground with a jumper wire.
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad02
  1. Check for continuity between PCM connector terminal B23 and body ground.
    Go to step 13.
    NO -
    Repair open in the wire between the IAC valve and the PCM (B23).n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad03
  1. Remove the jumper wire from the IAC valve 3P connector, then reconnect the IAC valve 3P connector.
  1. Measure voltage between body ground and PCM connector terminal B23.
    Substitute a known-good PCM and recheck. If the symptom/indication goes away, replace the original PCM.n
    NO -
    Replace the IAC valve.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad04
May 17, 2014 | 1996 Acura TL Series
(3p 4)3 · (p 2)7
Ambiguous. In an algebraic expression the constant numerical factor must be at the left, and the exponent must be recognizable.
If the expression is
((3p^4)^3)*((p^2)^7)=(3^3)*(p^12)*(p^14)=27*p^(12+14)=27*p^(26)
If no raising to powers is intended, then
(3*4p)*3*(2*7)*p=(12*3*14)*p^2
Jan 10, 2014 | Office Equipment & Supplies
Bob was thrice as old as peter. Six years ago he was 4 times as old as peter . Find their ages now?
Correction: Bob is thrice as old as Peter.
Let b be the current age of Bob, and p the current age of Peter. Now, b=3p
Six years earlier the relations was: b-6=4*(p-6)=4p-24.
Take the 6 to the right side leaving b=4p-18
Remember that now b=3p. Use it in the equation above
b=(3p)=4p-18, This becomes 3p=4p-18 or 0=p-18, and p=18
Peter is 18 years old, and Bob is 3*18=54 years old.
Verification: 6 years ago Peter was 12 years old and Bob 48 years old. 48/12=4.
Aug 10, 2011 | Texas Instruments TI-84 Plus Calculator
Error 52
Your 3P printer with the 52 error is going to need a scanner motor assembly.
Have somebody local look at it before you put money into this printer.
Considering its' age it just maybe looking to retire.
Mar 30, 2011 | HP LaserJet IIIp Printer
How do I install a Ultrak KC-3p camera? I just have the camera and need all the attachments. what else do I need besides the camera?
The original Ko-1242CPUA system included a Monitor (KO-1242cpua), cameras (KC-3P) and cables (KO-60).
Dec 05, 2009 | Cameras
After I reformat my LG HDD video recorder to give me more space, it only clears a tiny portion. How do I clear the whole recorder? I am going to HDD format, and reformatting. Thanks
Do you mean it always shows 10Gb less space than the capacity of the drive. ie only shows 150Gb but you have a 160Gb drive? The reason for this is that it has 10Gb reserved for the buffer of the pause/rewind live TV.
Cheers,
Keith
May 22, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a 2004 Honda Civic 4 cyl. That has a code P1298 ''Manufacturer Control, Fuel/Air Metering''. This, I believe is causing multiple cylinder misfires. Can anyone tell me what the culprit is of the...
OK. Here's how to diagnose the P1298 error.
DTC P1298: ELD Circuit High Voltage
1. Reset the ECM/PCM (see HOW TO RESET THE ECM/PCM ).
2. Start the engine.
3. Turn on the headlights.
Is DTC P1298 indicated?
YES - Go to step 4.
NO - Intermittent failure, system is OK at this time. Check for poor connections or loose terminals at the ELD and at the ECM/PCM.
4. Turn the ignition switch and headlights OFF.
5. Disconnect the ELD 3P connector.
6. Turn the ignition switch ON (II).
7. Measure voltage between body ground and ELD 3P connector terminal No. 1.
YES - Go to step 8.
NO - Check the No. 4 ACG (10A) fuse in the under-dash fuse/relay box. If the fuse is OK, repair open in the wire between the No. 4 ACG (10A) fuse and the ELD.
8. Turn the ignition switch OFF.
9. Connect ELD 3P connector terminal No. 3 to body ground with a jumper wire.
10. Disconnect ECM/PCM connector E (31P).
11. Check for continuity between body ground and ECM/PCM connector terminal E15.
YES - Go to step 12.
NO - Repair open in the wire between the ECM/PCM (E15) and the ELD.
12. Check for continuity between ELD 3P connector terminal No. 2 and body ground.
YES - Go to step 13.
NO - Repair open in the wire between ELD and G201.
13. Reconnect the ELD 3P connector and ECM/PCM connector E (31P).
14. Start the engine and let it idle.
15. While measuring voltage between ECM/PCM connector terminals A24 and E15, turn the headlights on (high).
Does the voltage drop?
YES - Update the ECM/PCM if it does not have the latest software, or
substitute a known-good ECM/PCM, then recheck. If the symptom/indication goes away with a known-good ECM/PCM, replace the original ECM/PCM.
NO - Replace the ELD.
May 04, 2009 | 2004 Honda Civic
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
