Question about Ovens
Turbochef tornado will not load new menu from card. I enter the pin and 9, but it does not go to the load menu screen.
  • 14 Answers
SOURCE: turbochef tornado
F3 errors can indicate a mag problem. Check your fuses first, it can also be a door switch. If your fuses are good, you need to inspect the 2 magnetrons. If you have a burned tip on one the waveguide and waveguide cover will need to be replaced. I usually replace the entire system at a cost to the customer of $1500.00
Posted on Jul 31, 2008
SOURCE: F3 Mag Curr. on Turbochef Tornado
A posibility is that you have microwave leakage. you will need to adjust your door.
Posted on Mar 28, 2009
  • 75 Answers
SOURCE: Problems with TurboChef TORNADO Electric Oven f8
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
Posted on Jan 28, 2010
  • 75 Answers
SOURCE: I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
  • 17 Answers
SOURCE: My turbochef tornado gives an error messag of
Could be the speed control PCB, or the motor, You need to test the impedence of the motor. You may have to replace both the motor and the PCB.
Posted on Mar 01, 2010
I bought my turbochef NGCEW ex Subway. It heats up no problem and then shows the Subway menus but I can't seem to access the edit menu. Also, some of the keys don't beep when I press
This might help you out:
http://www.basequipment.com/v/service/TurboChef/NGC.pdf
It's a service manual for the TurboChef NGC Tornado.
Pay particular attention to pages 15 through 19. It shows you how to edit menus and to reset everything.
Oct 21, 2014 | TurboChef TORNADO Electric Oven
How to find error codes
press the back key twice.
press back + enter at the same time.
type 9-4-2-8 (text the word "what")
then enter
press the faults soft key.
Mar 23, 2013 | TurboChef TORNADO Electric Oven
Turbochef tornado toaster wont get to menu, just warming up
The most common issue with this is a bad IR element. When the oven is cold remove the metal rack. you will see the IR element on the bottom. turn the oven on. wait 1 min. open the door and see if the bottom element is warm at all. If the bottom element is still cold then you have a bad element.
Feb 13, 2013 | TurboChef TORNADO Electric Oven
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
I have a turbochef tornado and the panel wont light up at all, or oven start. when i turn the power on, all i can hear is a very faint mmmmm or whirr for a second then nothing, and nothing comes up on the...
you may need to change the I/O board usually around 420 to replace. once you take the top and right cover off look at the I/O board the connector at the bottom is for the keypad sometimes this comes loose and can cause the keypad to not work correctly.
enter test mode
when the oven is off press back and enter at the same time then type in pin 9428 then press enter
select self test and follow on screen directions
hopefully this will give you some insight as to what is wrong
if you have any problems entering test mode and you have checked the connector and the bottom of the I/O board just replace the I/O board
Dec 11, 2009 | TurboChef TORNADO Electric Oven
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Dipending upon what kind pizza you want to use.
Subway using the same toster to Bake personal pizza (90 Second for 1 and 120 sec for 2 pizza
Oct 17, 2009 | TurboChef TORNADO Electric Oven
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
TURBOCHEF C3 AND TORNADO
what setting. the code to get into diagnostic area is 9428.
Nov 22, 2008 | TurboChef TORNADO Electric Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
