Question about Kenmore Progressive Canister Vacuum Relay Switch
My Kenmore Progressive 116.25614 won't turn off with the switch, I have to unplug it each time. How do I clean the relay points?
My Progressive vacuum won't turn off at the switch. I have to unplug it each time which is annoying.Someone suggested that I first try to clean the relay points. How is this done?
  • 184 Answers
SOURCE: kenmore Progressive 25614 vacuum
check the reset button on the brush assembly which is also called the power mate. if not then take it to your local sears repair center. if it is the pc board. sears has them in stock. I think it is about $7 for the part.
Posted on Feb 05, 2008
reddevil6
  • 1673 Answers
SOURCE: Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Posted on Sep 02, 2008
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Posted on Dec 05, 2009
  • 20 Answers
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
Posted on May 06, 2010
Get the belt to turn in Progressive Whisper belt
Make sure the roller is not jamed with carpet threds , remove bottom cover and clean dust balls and obstructions out see if ti resolves problem make sure it's unplugged when checking and install complete before applying power!
Feb 21, 2015 | Kenmore 25614 / 25615 Progressive Bagged...
On off switch will not work --always on on
sounds like the start relay is shot if you have a switch on the handle that turns on the vac
the relay then is in the motor compartment
Mar 03, 2010 | Kenmore 25512/ 25513 Progressive Canister...
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive 360 will not turn off
I have the same problem. Couldn't turn it off and now it doesn't work for the floor setting (though I can now turn it off). I suspect the switch in the handle is the problem but having trouble opening the handle...
Sep 22, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuum will not shut-off
if it has a foot pedal flick it a few times and see if it goes off.if its a switch unplug the vacuum and move the switch from on to off real fast a few time.if you have any contact cleaner you can try to spray a little into the switch while unplugged and work the switch back and forth a few times .the switch might just be dirty.if you don't hear a click when you turn it ioff and on then the switch is probably bad.please leave feedback.i hope i was some help to you
Mar 30, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Vacuum won't come on
The switch in the hose maybe bad, motor problem, or some of these cannisters have a relay mounted by the motor, it may be bad.
Mar 16, 2008 | Kenmore 25512/ 25513 Progressive Canister...
On/off switch needs repair
you don't have to repair the switch. your vac may have a relay inside the canister which may be defective
Sep 13, 2006 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore Progressive Canister Vacuum Relay Switch Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
