Question about Cadet Manufacturing Heating & Cooling
One side of heater is blowing cold air,one side is blowing warm air
    Problem Solver:
  • 16 Answers
You have a element out
Posted on Feb 12, 2015
  • 252 Answers
SOURCE: my fridgidaire gas furnace is blowing cold air
Today’s furnaces are controlled by a computer which constantly monitors for problems. When it detects a problem it will shut off the burners. Depending on the problem and the specific furnace it will either “lock out” the furnace or cycle it through a purge (to rid it of un-burned gas and excess heat) and then attempt to re-start it. If the problem continues to occur then it will “lock out”. Depending on the problem and the furnace it may again attempt a re-start after several hours. In any case if the problem was not detected/caused by a sensor which requires a manual re-set, when the power to the computer is interrupted or the call for heat is interrupted the computer is reset and it will again attempt to re-start the furnace. The most common problems are:
· Low or lack of flame sense. Different furnaces use different methods to detect a flame – often these “flame sensors” become dirty and have to be cleaned (usually with sandpaper or steel wool).
· Bad igniter. (Doesn’t light at all).
· Clogged combustion air intake or exhaust.
· Clogged condensate drain. (90+% efficient furnaces).
This is not a complete list, only the most common!
Depending on where you live your HVAC system runs more than anything else you own (including your car). All furnace manufacturers “recommend” “regular maintenance” of your furnace. In fact, all that I am aware of state in their warranty that the warranty may be voided due to lack of “regular maintenance.” The industry has defined “regular maintenance” as yearly (in fact, some manufacturer’s warranties state yearly). Due to safety, liability, and the need for many other things to be checked, cleaned, and/or adjusted (2-page checklist where I work) to ensure safety and efficiency. Due to the large number of furnaces and the differences between them. Moreover, due to the terms of this site, I WILL NOT AND CAN NOT give you specific instructions on how to perform repairs on your furnace. I suggest that you contact a local, reputable, HVAC service company for (a tune up, preventive maintenance, general maintenance, yearly service call, general service, or whatever they call it).
While I may not have told you how to fix your furnace yourself, I have told you how to fix it. Please rate my answer.
Posted on Mar 14, 2009
  • 189 Answers
SOURCE: The Heater is only blowing cold air
I would need a lot more info. if this is a natural gas furnace you may have a bad hot surface ignitor
Posted on Mar 28, 2009
  • 5 Answers
SOURCE: My vornado heater doesn't blow hot air
YOU PROBABLY HAVE A BURNT OUT HEATING COIL
Posted on Sep 29, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 01, 2009
  • 185 Answers
SOURCE: DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Posted on Feb 02, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Heater work on one side
Right side blend actuator bad or system recalibration required
Mar 10, 2014 | Cars & Trucks
Warm aire on one side cold air on the other
Does it have passenger side controls
Feb 25, 2014 | Cars & Trucks
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
Fully warmed up; blowing hot and cold; Suzuki XL-7
Its just a vent damper plate not operating, it's like a gate which controls the flow of air,,usually they are operated by vacuum, or cables.
Service center time, unless you are handy with your own repairs.
Jan 19, 2009 | 2004 Suzuki Verona
Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Jan 18, 2009 | 2001 Dodge Grand Caravan
Heating & Cooling Logo
59 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
