Question about Hardware & Accessories
Set legrand timer - Hardware & Accessories
3 Suggested Answers
SOURCE: I have a Hager (leGrand)
http://waterheatertimer.org/How-to-program-Hagar-timer.html
Posted on Apr 27, 2011
SOURCE: how can i set the on and off of my legrand timer
You posted under GE timer, but say you have Legrand, and don't include the model number or type of Legrand timer.
1) The only Legrand timer I have in my files is the RT1 countdown timer
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#RT1
http://waterheatertimer.org/images/RT1-timer.jpg
To set RT1, you push one of the buttons, and fan-or-light turns on for a duration of time, then automatically turns off. Use the large button as ordinary light switch.
2) Legrand also makes commercial line of timers, including din rail timers and pin-type timers
http://www.legrandcommercial.com/control_timers.htm
3) If this is not your timer, add a comment and include in-focus photo of your timer for possible identification.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
How do I program a Legrand 04761 timer?
Generally, the instructions are shown below: you will have to fiddle around to tweak the instructions since this model Legrand is discontinued, and replaced with the 412641
There are 4 programming buttons located on face of timer: menu, on, +, -
Press menu, use +- to scroll down to GCFEIL, Press on, select language
Press menu, use +- to scroll down to set, press on, set current time and date using same basic commands.
Press menu, use +- to scroll down to program, press on, select new, press on, select day-days of operation for program 1, select individual, set On and OFF times for program 1, save
Press menu, use +- to scroll to function, select auto to run programs.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 02, 2015 | Legrand Hardware & Accessories
How to set legrand timer switch 12 hours model # 037-55 microrex qw31
QW31 is 7-day analog timer, 230 Volt
http://waterheatertimer.org/How-to-set-timers.html
If there is a photocell override, then it will be wired into terminals U1 and 4, and will not be part of the timer setting
Gene
Oct 15, 2014 | Legrand Ivory Universal Timer Controlled...
Legrand Circuit Breaker Wiring
When fixya appears on 1st page of search for product, then either the product number is not right or product is older or product number is not exact.
What voltage are you using?
What is a Legrand 060-12?
What is a C2 Rcd?
What controls the auto function overnight... a timer?
Which timer...?
Probably a change in wiring at timer will work, but then the timer buttons might not have any affect for override on-off.
You could put in a DPDT bypass switch or bypass timer... that connects to incoming wires before the auto timer and then connects to wires after timer.
Nov 17, 2013 | Electrical Supplies
I have a 16 amp Legrand electrical timer cat 037 30 on my hot water system. How do I program it?
Legrand 037 30 is vertical analog timer similar to hagar EH 010
Open following link for illustration how to set and wire timer.
http://waterheatertimer.org/images/EH-010-2-2-500.jpg
Hours of the day appear on timer dial as you rotate dial around.
Hagar timer you push segments left for ON times, and right for OFF times.
To set current time, manually rotate 24-hour timer dial until current time lines up with mark.
You can also move some of the segments to the right and leave rest of segments to the left.
Then manually rotate timer dial several rotations with thumb while listening to the hot water system turn on-and-off, or use tester to test power at terminals 3 and 4 or use tester at hot water system.
If timer has override lever, then move lever to each position and repeat test by rotating dial with each switch setting.
Jun 30, 2011 | Hardware & Accessories
How can i set the on and off of my legrand timer switch
Apr 26, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Hardware & Accessories Logo
14 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
