Question about Boston Acoustics TVee Model Two TV Speakers
Sub woofer will not work power lamp comes on green then turns to red
Floor base will not work, powers up green then turns red and no sound?
2 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: No power through to sub, red light constant, green light flashing
Sounds like you've blown either the input or output stage on this. Just need to open it up and inject a signal to see which end is toast using a scope.
There are quite a few professional sound technicians about who do repairs, so try your local area to see if there is a local tech to fix it for you. Usually people who hire DJ's or fix their equipment do this day in-day out.
Try and get a "no fix-no fee" out of them (which is not unreasonable) - and leave your 'phone number on it (in pen). - sometimes they have so much stuff it's hard to remember who owns what.
Expect an hours labour plus parts - which are minimal.
Posted on May 07, 2010
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Can`t power it up. Connections and fuse OK. Stopped working after switching off and would never switch back on. LED indicator light`s neither green nor red but simply off.
First, I have to commend you for having a really fine piece of equipment. Mission makes great products. Now down to business. Being where I am and not being next to your sub-woofer with test instruments and tools I'm going to be so basic as to almost be insulting. However, If I were there, I would be testing these things.
Normally, when one has a catastrophic failure. i.e. no power, and no indication of power present one starts with the power supply. And that starts at the power company.
1st Determine if there is power in the actual outlet that the unit is plugged into. I have found that when installing a sub-woofer on a two plug wall outlet, for example, it might be plugged into a plug intended for a floor lamp. and is turned on and off by a wall switch. Many residences have this feature. It is usually one of the two plugs in an outlet. So you have to test the actual physical outlet. If the outlet is off, check the light switches. If there is no power to the outlet, check the household circuit breaker.
Let's assume that everything works, so far.
The next thing to do is check the internal fuse with a meter. If you don't have one, pick up a multimeter from Radio Shack or Walmart for less than $20.00 or Harbor Freight for less than $7.00
If the fuse looks good but checks out bad (sometime happens) replace it with A FUSE OF THE SAME VALUE. DON'T STICK IN A PIECE OF ALUMINUM FOIL OR BYPASS THE FUNCTION AND PURPOSE OF THE FUSE. The fuse costs a dollar, at the most, the Sub-Woofer costs $800.00 at the most.
OK, so now you have either a working sub-woofer, or an elegant paper weight.
If it is still being a paper weight, contact mission to locate an authorized service company. This piece of equipment in not designed to be user servicable
Here is their link below,
I hope this helps,
Best Regards,
Mark
http://www.mission.co.uk/Default.aspx?lang=En
Jan 20, 2011 | Mission M5AS Subwoofer
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
I need a wiring legend for the Rampage BA200 sub woofer
Red - power
Black - ground
Blue - turn-on (switched 12 volt)
Green and Gray -- Hook to factory/aftermarket stereo for the signal.
Jan 14, 2009 | Car Audio & Video
Subwoofer powers up and clicks off after 2 seconds, no sound, ever.
if you know what a transformer is, and if you have a multimeter, i suggest you to go ahead andcheck the transformer,
Nov 05, 2008 | JVC TH-C5 System
Sub woofer flashing red and green
sir,,i think there is something wrong with the connections or the cross over,,,kindly check it out or mjaybe the cone of ur speaker is damage,,,hope too help you thnkss??
Jan 27, 2008 | Kenwood SW36HT Subwoofer
Boston Acoustics TVee Model Two TV Speakers Logo
119 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
