Question about Sony MegaStorage CDP-CX455 400-Disc CD Changer
Fix sony cdp c445 5 disc
Drawer wont open
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
  • 35 Answers
SOURCE: CDP 265 5-disc player
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
Posted on Mar 02, 2009
smarthome2
  • 1114 Answers
SOURCE: disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
Posted on Dec 22, 2009
fkuk
  • 311 Answers
SOURCE: Have had problems for a while not being able to
im probbaly guessing that the motor that drives the draw has given up and died what you could do is open it up and remove the motor from the draw but still have it plugged into the board turn on the cd changed and press the eject button and see if it spins without a load on it hopefully there is a model number on the motor it that you might be able to replace it with
Posted on May 10, 2010
tech240
  • 169 Answers
SOURCE: My Sony MegaStorage CDP-CX455 400 Disc changer
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
Posted on Aug 09, 2010
I have a sony cdp cx355 that seems to have a disc stuck and the door will not open to remove it. How should I proceed?
You have to remove the cabinet to expose the inner workings. Once inside, you should be able to see the stuck CD. Be careful to avoid damaging any parts of the player mechanism as you work the CD back into the carriage. You may find that once the CD is back in place normal operation resumes.
Sep 04, 2016 | Sony MegaStorage CDP-CX355 300-Disc CD...
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
How to fix a Sony 5-disc player that will continue to spin and not stop at any disc slot
There are opto's around the edge of the carousel so the machine can count it's position, maybe these are at fault
Sep 30, 2014 | Sony CDP-CE375 5-Disc CD Changer
Sony cdp-ce525 drawer won't open
How old is the DVD player? I have a Yamaha 5-disk player and the rubber drive belt that wraps around the drawer motor and connected to the pulley for the drawer was stretched out and useless. Just bought a new one online and voila!
Jun 16, 2014 | Yamaha CDC-745 5-Disc CD Changer
Cd drawer not opening on sony mxd-d4
Could be bad belts, lack of lubrication on the MD side and even a bad power supply filter capacitor of the larger type. It would need to be seen by a repair Technician to resolve all issues.
Jan 20, 2013 | Sony MXD-D40 MiniDisc Player/Recorder and...
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Sony cdp 350 compact disc player will not spin to read disc once drawer if closed, it will buzz a little then drawer will open. If disc is in player and using a screw driver on bottom to manually open and...
There's never been a better time to switch to Juniper. Right now, you can reap the rewards of being a part of the new network - in just a few days. Juniper EX Series switches are standards based, so implementing them with your existing network is easy and seamless. And the benefits are huge. At least a 30% reduction in capital expenditures. Increased efficiency. Less energy consumed. And a network that's easier to maintain and operate.
We'll work with you to find the most cost-effective solution for your specific needs. In return, you'll get a fully automated solution that readies your network for anything that lies ahead. You'll get your new switches in a couple of days - not in 6-8 weeks. And we'll be ready to provide any support you and your employees might need. Your network will be more streamlined, more efficient, and more cost-effective.
Dec 01, 2010 | Sony Audio Players & Recorders
Have had problems for a while not being able to open the drawer of my Sony CDP-C5F Compact Disc Player. It required my jiggling the cover a bit until it would open. Now it won't open at all. I realize this...
May 10, 2010 | Sony CDP-C505 5-Disc CD Changer
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Sony MegaStorage CDP-CX455 400-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
