Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hitachi rear projection screen comes and goes
ctf1800
  • 4402 Answers
SOURCE: Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
mistersony
  • 320 Answers
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: Hitachi 53" rear projection is losing its picture.
If you are not experiencing any shift in colors, it sounds like the power supply is failing since this will affect all three colors.
Posted on Feb 28, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Oct 30, 2009
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
Keeps losing picture,Still have sound
Call him back and tell him that your tv has bad connections. He will check for bad connection on main board in horizontal..........
Sep 13, 2009 | Hitachi 46F500 46" Rear Projection...
Black box in middle of screen
go into the menu and turn your closed captions off or if there is a cc button on your remote you can turn it off that way.
Sep 08, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 55ex15k projection tv
my hitachi 55ex15k will come on and work for a while then the screen goes really bright and some lines come through the entire picture then it shut off
Jun 17, 2008 | Hitachi 57F500 57" Rear Projection...
HITACHI TV MODEL 57F500A
My hitachi 57f500a wont turn on i pulled the back off and there are only one green light on and the relay keeps clicking when the relay clicks another green light flickers and the red one come on and goes off.
May 04, 2008 | Hitachi 57F500 57" Rear Projection...
Bad picture on a Hitachi 53"
The problem is in the vertical sweep ckt. and is heat related. Would need to be repaired by a tech.
Electrode
Feb 28, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Green Area in Lower part of screen
Some Hitachis have developed bad connections on the convergence output IC's (locations IK04 and IK05) You could try and resolder the IC's but if you are in it that far you are best to replace both. The generic part number is STK392-110
Nov 29, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi TV
May have a CRT going south on you. This is actually a more common problem than once thought...accordianman
Oct 11, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 50 inch Rear Projection Color problem
Which sounds like a loose connection in the video or chroma section. you can carefully tap around affected area with a rubber screwdriver handle(not metal part) and see if it does come and go and look in that area for loose connections that needs soldering back. Hope this helps
Jul 30, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
