Question about Sony DPP-FP95 Digital Photo Printer
Ink Ribbon can't be removed
Tried to print a photo but it keep saying no print paper. I checked everything seems okay (P size, paper tray okay, no paper jam) and press print but not working. Finally I checked the ink ribbon and tried to remove it but can't be removed which I believe is the problem in printing. How do I remove the ink ribbon off the printer because it seems stuck in there? Or do I have to take it to Sony dealer for help? Thank you.
SOURCE: Does not recognize print paper
need installer lost the cd
Posted on Apr 27, 2008
  • 399 Answers
SOURCE: Picture Station Sony DPP-FP55
the printer needs a proper servicing and dust cleaning done.as there is a sensor in the printer which detects whether there is paper ,or no paper in the paper tray ,that sensor is moved from its orignal position so this problem is coming.but servicing and cleaning will help.
thanks
Posted on Sep 18, 2008
SOURCE: Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Posted on Apr 14, 2009
  • 85 Answers
SOURCE: MY SONY UP-10L SNAPLAB PRINTER GIVES ME THE
Hi
This sounds like the sensors are damaged. Best taking to a computer repair centre to be checked out as sony parts can be hard to acquire.
Thanks
Taz
Posted on Oct 23, 2009
  • 8 Answers
SOURCE: ink ribbon or paper roll error. the in ribbon is
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Posted on Jan 26, 2011
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
Paper cassette is not seated correctly. check for paper or objects blocking the cassette path. reinsert the cassette and press Start. keep getting this message. started after printing and installing...
I had this same problem and tried everything (I thought) to fix it. Then I saw the solution at:
http://www.retrevo.com/c/sohohelp/blogs/show/6633/I-just-had-my-espon-artisan-800-replaced-and-the-refurb-keeps-saying-that-the-paper-cassette-is-not-seated-correctly#replyForm
Basically there is a plastic pin that tends to break off and stays in the area where the cassette is loaded. It takes up just enough space to keep the cassette from being pushed in all the way. The solution is to turn the printer off, unplug it, then lift up the printer so the broken pin falls out. Once it comes out, the printer will work fine again.
May 12, 2011 | Epson Artisan 800 All-In-One InkJet...
HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
I am getting error when I send print job to Kodak 1400 thermal printer. The media light flashes but can't find anything wrong with paper or ribbon. Any suggestions ?? Thanks. Debby
Hi Debby,
If you remove the paper tray and the cradle holding the ribbon you will se a BLACK holder on the RIGHT hand side of the machine were the Ribbon Cradle sits.
At the bottom of this BLACK holder you will see a small hole. If you get get a cotton bud and put some glass cleaner on it and wipe the 2 sensors in this hole. Replace the Cradle and Paper tray and try it now.
If this does not work have you tried checking that you have set the right paper size and type in Printer Properties.
Thanks
Gary
Mar 15, 2009 | Kodak PRO 1400 Thermal Photo Printer
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Jun 23, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Sony DPP-FP95  Digital Photo Printer Logo
94 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
