Question about Samsung YH-925 MP3 Player
Reproductor muerto Hola tengo un yh-j70 y lo formatie sin el software del pc, el caso es que le borre el sistema y ya no arranca, ayuda por que ni se conecta al pc ni nada, ya probe entrando a administrador e instalando el driver del pc pero no funciona
  • 5 Answers
SOURCE: cannot charge my yh-j70
When I first got my yh j70 I had the same problem. Have you made sure its in 'charge' mode? When you go to 'settings' there is an option tha allows you to switch from 'charge' mode to USB connect mode. You have to switch it depending on what you are trying to do. Hope this helps.
Posted on Dec 08, 2007
SOURCE: recognizing samsung yp-u3
my computer say when i go to connect it cannot connect i onli got it today do u know what i cud do??
Posted on Jul 22, 2008
SOURCE: Samsung YH-J70
Keith, I have the same problem. Do you already have a solution?
regards Jeroen
Posted on Oct 20, 2008
  • 18 Answers
I had the same problem - the hard drive had failed, which is a common fault. I bought a new one on eBay - a Toshiba MK3006GAL 30GB - which worked fine.
BUT... the drive came completely unformatted and I had to format it on a laptop first as I could not get it to format in the YH-J70. If the drive is FAT32 format, however, you should be OK to just put it in the YH-J70 and format it with Samsung Media Studio.
Posted on Dec 31, 2008
  • 18 Answers
SOURCE: samsung digittal audio player yh-j70
All the drivers and software are still available for download on Samsung's website.
http://www.samsung.com/us/support/
Posted on Dec 29, 2009
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Hola, tengo un controlador behringer BCD 2000 y mi portatil es de windows 7, el problema es ke los driver del controlador no estan actualizados (hechos para XP) y por lo tanto no puedo hacer funcionar...
Hola, pruebe este enlace http://www.driverscape.com/download/Behringer-BCD2000-v1.0.0.6 detecta su sistema operativo para darle el controlador correcto para su ordenador. No entiendo el espa?ol. ยก sin embargo, he traducido al ingl?s!
Jul 22, 2017 | Computers & Internet
Buenas tengo un Sunfire 2002 gt dos puertas , tenia pensado instalar un reproductor de cd pioneer, pero me acabo de enterar que la alarma del sistema del vehiculo pasa a través de la radio, sera...
Este auto esta equipado con un sistema de audio adelantado por lo tanto al reemplazarlo deberia utilizar un adaptador GM VT-GMRC-01 para que pueda mantener el aviso de algunas funciones (warnies) que la computadora envia y ademas este adaptador envia 12 voltios al radio para que este funcione, no le aconsejo que cambie el radio sin este adaptador, por lo demas no hay ningun problema.
Un consejo mas si cambia el radio es mejor cambiar tambien la vocinas para obtener un mejor sonido y aprobechar la calidad del nuevo stereo
Dec 09, 2010 | Pontiac Car Audio & Video
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Problema en el ps2
Amigo, creo que solamente se dasabilita eso por el jumper, pero la pregunta es, el board sin teclado conectado funciona, o sea despierta, si es asi, conecta el teclado USB cuando la maquina este funcionando, con el sistema operativo (windows, linux, o el que sea) , si no arranca, puede ser problemas de memoria, prueba cambiarlas y me dices, un saludo Marlon de la Rosa
Feb 01, 2009 | AOpen MX4LS (91.88Q10.001) Motherboard
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
NO SYSTEM ON HDD
I FIXED! LO ARREGLé!!!!... Mi objetivo era ponerlo a funcionar de cualquier forma y LO HICE!!, igual que todos, lo formateé y me comenzó a dar el error del sistema en el HDD, prácticamente tenía un DD portátil. Ahora lo tengo funcionando con el software libre “ROCKBOX” el cual tiene solamente ventajas en comparación al limitado firmware del GIGABEAT y es abrumadoramente más completo y, por ejemplo, no se necesita nada ni similar al “GIGABEAT ROOM” para cargarle música al reproductor pues es tan simple ahora como copiar y pegar (inclusive desde el WINDOWS VISTA) . Los pasos exactos no los podría decir pues fue puro ensayo y error pero es simple, deben buscar el “ROCKBOX” para GIGABEAT serie F en la misma página de ellos (totalmente gratuito) y también buscar la carpeta “GBSYSTEM” pero en Internet, desgraciadamente no puedo dar la dirección exacta pues no la guardé pero no tardé mucho y OJO, no sirve la carpeta “GBSYSTEM” que viene con el cd del reproductor, esa está vacía o con unos archivos ocultos, la que se baja de la red trae al menos dos archivos del tipo “FWIMG” (es más, estoy casi seguro que en la página de “ROCKBOX” explican como conseguirlo de forma simple), la pegan en el reproductor conectándolo como USB. Teniendo todo ello listo, van instalándolo según las indicaciones del PDF que está en la página de “ROCKBOX”… Mucha suerte!!!! Y apreciaría que me contaran si tuvieron el mismo éxito que yo a josedanielcr@gmail.com.
Oct 04, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Samsung YH-925 MP3 Player Logo
15 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
