Question about Hughes HRMC11 Remote Control
Program my remote to a new 32 in Vizio TV - Hughes HRMC11 Remote Control
How to program my rca remote 311w to my vizio tv?
If your RCA remote is programmable, you can use its "code search" function to find a code that will enable some or all functions of your Vizio TV. If the search produces no result, you may have to try another remote.
Aug 14, 2014 | Vizio L32 32 in. LCD HDTV
Have a 32" vizio 1080p and i need the remote code for a direc tv receiver
Please contact the satellite provider, and they will program the remote, or use a universal remote that supports both units.
Good Luck!
Alex's TV Service
Feb 17, 2010 | Vizio L32 32 in. LCD HDTV
I am trying to program my vizio remote to work with my uverse box. would you know the code? other ways around it??
Vizio Television 1343, 1018, 1004, 0178, 0502, 0627, 1756, 1758, 0128, 0117, 1017, 1078, 0030, 0056 VIZIO HDTV 1004
If your tv is HD mute wont work.
This is for programming the uverse remote to the vizo tv. From my understanding the uverse box doesn't have a code.
Dec 01, 2009 | Vizio Televison & Video
Code for vizio tv
If you mean the code for this brand that you need to program a remote control, you will need to check the instructions that came with the remote. Device codes are assigned by the remote manufacturer, not by the TV maker. The code for a brand of TV won't always be the same from one remote to another. If you've lost your instructions, you can usually find them at the manufacturer's website, or get the information from your cable company if it's the cable box remote.
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Vizio 0891, 0912,1783
Feb 27, 2009 | Vizio VW37L 37 in. LCD HDTV
Cannot program remote for tv
Here are the codes from Visio's tech support line:
These are listed in order of probability and are for remotes using four digit codes. Call them if you need a three or five digit code.
1758
0178
1756
0128
0117
1017
1078
0030
0056
0205
1292
Good Luck
Jan 03, 2009 | Vizio L32 32 in. LCD HDTV
Dtv universal remote
I'm using a universal remote with code for an LG 0178 (or 101780 AND IT WORKS
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Vizio "no signal"
We just had this problem and it was the cable that came with the set. Once we replace this, it received a picture, however, now the volume and on/off does not work on the Verizon remote.
Jan 31, 2008 | Vizio GV42L 42 in. LCD Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Hughes HRMC11 Remote Control Logo
26 people viewed this question
Top Hughes Televison & Video Experts
jason
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
