Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
Remove back and bezel - Citizen Eco-Drive Calibre 8700 Wrist Watch
The bezel ring is stuck
These bezels sometimes get clogged with dust and dirt, it will need to be removed and cleaned, there is a small spring underneath so care must be taken so it is not lost while removing the bezel
Sep 28, 2013 | Swiss Army Wenger Watches
Need to change battery in EH23sa
The battery is actually accessed from the front of the watch.
You should have a "Case Knife" to remove the front bezel.
Remove the band first.
Set the watch in its side. Set the case knife at the groove where the watch band holder meets the front bezel, and give the back of the knife a sharp rap with a small hammer. The front bezel should pop off.
Some watches have a small circular plastic piece that will also come out. Gently remove the movement from the front. The battery (CR 2025) can then be removed from the back of the movement using a small, thin blade. Install the new battery. The inside back of the case should have restart instructions. (Push A -left button once. then push and hold A until hands move to 12:00. Push B once to start reception.
The back of the watch is plastic. Don't try to remove it.
Gently re-assemble movemengt. A watch case press tool is best for finishing assembly. I would suggest taking the watch to a jeweler if you are uncomfortable taking this watch apart. Good luck
Mar 21, 2011 | Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
Hi, I have a casio ef532d 1avef watch and I would like to remove the bezel in order to restick the 10 (or 22) mark on the dial, as it is wandering under the glass. Does the bezel go out or should I open...
Thank you for contacting FixYa.
You can not do this yourself. You can not remove bezel as it is sealed. To go through the back requires removing all the watch inside components and you will have to remove the winder. NOT RECOMMENDED TO DO YOURSELF.
Take to a local watchmaker, or send here:
http://www.casio.com/support/authorizedservice/
Best regards. Jewel
Sep 15, 2010 | Watches
Navitimer 2 rotating bezel has gone very stiff to turn how can i free it up?
This depends on what exactly is causing the problem. If the bezel is bent from a sharp blow it would have to be replaced. It could be there is dirt under the bezel. To clean this there are two possibilities. If your bezel has screws around the outer edge they will need to be loosened or unscrewed to remove the bezel. These are small screws so be careful you don't loose them. The bezel should then lift off. Clean it with mild soap and water and dry it well. Be careful of the bezel spring. it is easy to break the little fingers. Wipe off any dirt on the case and set the bezel spring and bezel back on the case. Use Red locktite on the screws and reinstall them. If you have markers on the bezel that come off when you remove the screws be sure you keep track of them and the screws that went with them.
If your bezel does not have screws but fake ones then the bezel should be removed by a qualified watchmaker because the bezel could be bent or damaged when removed.
Hope this helps.
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Watches
How to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
Sep 18, 2009 | Watches
Taking the glass from my watch
Rolex glasses are held in place by the bezel ( ring surrounding the glass ). Bezel must be lifted off first in case if the glass must be removed. Rolex bezels are friction fitted and are very tight. Usually special tools are used for bezel lifting, but in skilled hands the watchmakers knife can do the job as well (inserting the blade between the bezel and case and slowly prying up all athe way around).
In most cases the bezel still holds the glass when lifted off the case. To release the watch from bezel ring you will need a special press with dies as you will need it for refitting glass and bezel on to the case.
I would advice to find your nearest watch repair shop and ask for help, because without proper tools it is allmost impossible to remove and reset Rolex glasses without damaging them.
Do not forget to rate, please.
Jan 21, 2009 | Rolex Submariner 16618 Wristwatch
Replace bezel for omega seamater
I would recomend taking it to an independent watchmaker. It should only be $15, $30 to make the change.
Most bezels are pressure fit. Using a small jewelers knife to pry the bezel from the case is how most bezels are removed.
My friend is a watch maker and he has a special tool that removes the bezel however he told me he only uses it when he has customers watching. Because the old knife looks pretty brutial, but works better.
Dec 27, 2008 | Omega Seamaster 2541.80 Wrist Watch
Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Dec 19, 2008 | Timex 1440 Nylon watch
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
32 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
