Question about Dishwashers
3 second light wont turn off model number ffbd2406nwoa
Solid red light
I would say the laptop is overheating. But wont be able to say without doing a few things. give the model number of the laptop so that we can get the error light info from the user guide. what happens is you leave the laptop for a while and turn is on again?
if it goes on then is is overheating and needs cleaning otherwise the could be other problems an the best would be so contact Samsung support to help trouble shoot .
Jan 03, 2014 | Samsung Computers & Internet
Land cruiser 2010 timing belt warning light ON, how can reset?
not sure if thes will work for you but try it you wont lose any thing :
turn the key on hold the odometer button in and turn the key but don't start the engine and keep holding the button for 10 ten seconds then lift your finger off the button and the number 1 should come up now this number represents 10,000 K's so what you do is keep pushing the button until you reach the desired K's you want you can go up to 20 = 200,000 K's and then you hold the button in for another 10 seconds then let go and turn the key off and turn it back on and it should be gone i know this works because I've just done it today
Mar 26, 2013 | 2010 Toyota Land Cruiser
My tv wont turn on
To begin with the model listed here does not have a lamp, it has three picture tubes so we have the wrong model number--willing to try to help but need correct model number.
Dec 12, 2012 | Mitsubishi WS-55613 55" Rear Projection...
The dryer just stopped and now wont turn on
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
Rca tv wont stay on turns on then blue light accross the screen then goes off in seconds
it is listed here as a 27 inch set--can you confirm the brand and model number for me ???
Mar 24, 2012 | RCA F27450 27" TV
Control lock light on my front load washer,I cant get it to turn off. washer wont work now
If it is a Duet model there press the button at 5 o'clock for more than 3 seconds to unlock the control panel. If it is NOT a Duet model... we need you model number ot help you as there are different methods of unlocking the controls depending upon the manufacturer and model. So plese provide a model number if possible... or at least a brand and what you think it is. Thanks.
Kelly
Mar 18, 2011 | Washing Machines
The tv wont turn on. It blinks red every so many seconds. sometimes it turns on for 2 seconds and then turns off.
Hi, the periodic red light is an indicator of a circuit failure, on some Television sets the number of blinks of the light will give a general idea of what circuit is malfunctioning.These sequences change according to make and model. As mentioned before it usually points to a general area and most of the time it's best to take the TV in for an estimation to get an actual idea on what the repair will cost.
Oct 20, 2010 | Televison & Video
Dishwasher wont turn on
Cant help without a model number as there are different locking devices on the different models.
Feb 10, 2010 | Dishwashers
The sreen on my HP note book wont turn on. the lights work and i hear the gears running but the sreen stays off. ni indication at all. i was one it in the morning and when i turned it on latter, nothing...
Ok what is the model number of your HP? Pavilion? Get back to me with model number in the meantime, unplug a/c adapter and then remove battery...then hold in power button for 30 seconds and then plug in the a;/c adapter with no battery in it yet. Turn it on and see if that brings it back..if not get me you model for HP
Oct 10, 2009 | HP Computers & Internet
Dishwashers Logo
Top Dishwashers Experts
