Fujitsu split system won t turn
Changed batteries in remote,checked breakers and fuses still won't turn on
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
bobotfel
  • 236 Answers
SOURCE: I have a Fujitsu Split
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
Posted on Apr 16, 2008
rickzilla
  • 706 Answers
SOURCE: My split system LG LSK2463HL
Use this link to get the service manual, they walk you thru an entire series of steps to check it out beginning on page 43 and up.. http://136.166.4.200/contents/AC/LS-K2430HL/LS-K2430HL_Service_Manual.pdf
Hope this helps..
Posted on Sep 21, 2008
  • 340 Answers
SOURCE: The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Posted on Jun 21, 2009
  • 400 Answers
SOURCE: Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Posted on Nov 04, 2009
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
AC unit had a power surges from the electrical companny and now it only turns on the unit from the breaker panel but no response from the remote control. The fan comes on only when breaker is turn on.
If the outdoor unit does not come on, there is a fuse box mounted on the wall or near the unit. Try changing out the fuses and see if it comes on. Depending on the disconnect box, the fuses are hard to see. You may have to remove a plastic cover to see fuses.Let me know if this is your problem please. Good Luck, Shastalaker7
Nov 03, 2009 | Amcor Aire AMS241HX Split System Air...
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
Jun 20, 2009 | LG LSC121PMA Split System Air Conditioner
Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Jun 01, 2009 | Fujitsu Heating & Cooling
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
I have a Fujitsu Split air-con system - have power, but the maintenance and timber lights are flashing but unit not working - have cleaned the filters, changed the batteries to remote control unit.
Apr 16, 2008 | Heating & Cooling
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
