Question about Hand Tools
How to fix Stanley mr33
Jammed
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
Jan 12, 2015 | Heavy Duty Stanley Bostich Heavy-duty...
My Stanley PHT150 is jammed and I cannot remove the staple channel. The instructions do not address a jammed staple channel so, how does one remove it?
Hi Dave,
Nice and easy this one.... all you've got to do is remove the chrome coloured pin at the handle end. This then allows the magazine to be removed by pulling it from the front end. Just make sure that you've removed the pusher (Where you feed the staples in) from the back first
Sep 18, 2014 | Stanley PHT150C] SharpShooter Heavy Duty...
Bostitch sb-18508n won't fire
Its either jammed or you don't have enough air pressure. Make sure you have the recommended air pressure. If nothing seems to work, go to Stanley.com for instruction book and answer
Aug 18, 2014 | Stanley BOSTITCH FASTENING SYSTEMS...
How to fix bostitch electric pencil sharpener EPS4
You may have to disassemble it (with power disconnected) to find and remove whatever is jamming it.
May 16, 2014 | Stanley Black & Decker Bostitch EPS4 BLUE:...
Miss fire or fireing two at a time how to fix?
first check for the proper guage nails, then look for a jammed nail in the magazine area and also a bent driver and lastly make sure that when fired the piston retracts fully all the above will cause the misfire.
Jan 23, 2011 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Nail jammed in Stanley Bostitch SB-125BN Air nailer
Please see the link below and enter the model number. That will get you to a complete parts breakdown diagram from which you can dis-assemble the unit and remove the jammed nails.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=COqqlsL3wqMCFZxo5Qod4gOiag
Aug 17, 2010 | Stanley Air Tools & Compressors
Garage door opener won't work. Motor housing turns partial revolution but looks like transmission jammed. Motor broke from mounting screws. Stanley Premier, came with house, maybe 25 years old. Time for...
THE OLD STANLEY UNITS ARE NOT WORTH FIXING.
PARTS ARE NOT AVAILABLE AND THE UNIT DOES NOT MEET THE SAFETY STANDARDS
TIME TO BUY A NEW CHAMBERLAIN / LIFTMASTER / OR CRAFTSMAN OPENER
GOOD LUCK
May 23, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Hand Tools Logo
102 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
