Question about Watches
Tissot t touch showing baee - Watches
Top button does not work
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Tissot watch manuals. Rate me, please
Apr 01, 2010 | Tissot T-Touch T33759851
My tissot t touch shows a temprature way low than the real one.
The watch will show body temperature until you remove it from your wrist and leave it in the open air for a few hours whilst it acclimatises and then reads the ambient temp, not your body temp.
This renders the thermo pretty useless.
Aug 17, 2009 | Tissot T-Touch T33759851
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
Help me please by using my tissot t-touch. my thermo function show´s 80 C on the display. i expected 30 C. But i can´t find a way to reset the values ?
The thermo function will show your body temperature while you wear the watch. For ambient air temperature, remove the watch and let it settle to ambient temp for about 15 minutes. Then it will read correct air temperature.
Jul 19, 2009 | Tissot T-Touch T33759851
Hi guys, my Tissot Touch watch has a non sinc problem with the digital and analog time. any solutions? thanks, Rodney
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
Jun 30, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot touch - the middle button came off hence
Here is the link to original Tissot website:
www.tissot.ch
I'm not sure if they will be willing to get in touch directly to the customer, but you can give it a try.
Please, note - you are asking for direct approach to Tissot, which is exactly what I did by supplying the link, so, my solution is 100%.
In case if you will not find there what you are looking for, it's not my fault.
Apr 08, 2009 | Tissot T Touch T33158851 Watch
Digital and analog display show different time
Paste this link into your browser:
http://www.t-touch.com/flash.html
1)Close available countries window,
2)Click on T-Touch, then choose Stainless Steel,
3)On the right side of the window click on film tab,
4)In the left box in the window find SYNCRO and click on it,
5)Watch and listen to instructions
6)Smile
Do not forget to rate, please.
Jan 19, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot setting instructions (for t-touch)
I downloaded a user's manual from Tissot's website. But it also dosn't give clear information. If you search from Google writing "tissot t-touch user manual", you will see some useful information. y. YAzar
Apr 28, 2008 | Tissot T-Touch T33159851 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
