Question about Jenn-Air JCB2282H Side by Side Refrigerator
Tuomatic ar3 fridge hi I have one of these fridges in my millard series 80 caravan can u sugest another fridge that will fit in its place?
We don't know how to hold down our vitrifrigo fridge in our motorhome. There were no instructions with the fridge.Its a C130 I.
talk with a caravan service center but you can remove the rubber feet and front adjuster bolts and use those points to bolt the fridge to the floor of the motor home
advice from people who install fridges to vans and motor homes would be a good place to start
May 06, 2017 | Refrigerators
Caravan fridge
See if you have access to a schematic on the unit itself. The fact that it works fine on gas tells you there is nothing wrong with the ammonia solution in the tubing. For that unit to work, the electric heating element has to boil off the ammonia and this is not happening. Check on the schematic if there is some kind of fuse or additional in line switch which is preventing the heating element from turning on and doings its job.
Nov 27, 2013 | Refrigerators
Fridge not getting cold enough..
Depending on the age and the make and model it can be recharged. If you let me know I should be able to tell you or you can call Mt Hope Hardware at 330-674-7474 and ask for the service department. We will be happy to assist you. Thanks
Jan 20, 2013 | Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
Thetford fridge type C11[fitted to caravan]model N80 PL R
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
Jan 04, 2009 | Thetford Porta Potti
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Tuomatic fridge operation
All the controls and instructions are under the kickboard at the bottom of the fridge. Hope this helps
Mar 13, 2008 | Refrigerators
Jenn-Air JCB2282H Side by Side Refrigerator Logo
26 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
