Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower idle fast - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Lawn man idles too fast
Could be a broken or worn throttle shaft,letting air in to the carb when it shouldn't !
Mar 22, 2014 | Mtd Arnold Corp RearMounted Bagger for MTD...
Removing blower housing
loosen the bracket on the engine holding the throttle cable start it and move the cable until it idles right but first check the idle screw on the carb turn to the leftwhile running
Apr 29, 2013 | Mtd Garden
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Yard machine model 11a-41mb029 idle
Hi, idle is not adjustable unfortunately they only have fast and a high rough idle, regards Phil.
Jun 02, 2012 | Garden
I start the engine and it sputters at fast idle and then eventually shuts off.
I think that after you start the engine you need to move the throttle lever off what you are calling fast idle (which is full choke). Simply slide the throttle lever down until it smooths out and runs properly.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Idles fast all the time once you start it up...........just started doing this and is only one year old.......
Other than the throttle sticking there may be a couple things:
The idle screw is mal-adjusted.
There is an air leak where the carburetor meets the block.
The governor spring has bound or streched (depending on type) affecting the RPM.
Jul 29, 2010 | Mtd 22" Yard Machine Push Mower
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
It is idling too fast and has a terrible vibration
The idle can be adjusted by moving, either left or right, a small lever in the front of the engine. The vibration is most probably caused by a lose or damaged blade or and excessive build-up of clipping under the deck.
Apr 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
Lawnmower cuts out on fast idle + runs rough
REBUIld carb it is dirty jet is clogged
May 25, 2009 | Echo Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
22 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
