Question about Konica Minolta Bizhub C353 Copier
C-5102 error in C353
How can i solve C-5102 error in Bizhub C353 printer.
  • Konica Minolta Master
  • 6,161 Answers
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Posted on Jan 23, 2016
Kevin Hayes
  • 167 Answers
SOURCE: Printers with full bleed capability?
NO!
Just like on a printing press that toner is being imaged somewhere when it runs out of the sheet. The toner is going on the imaging belt/fuser. Over time it will build up and ruin the device. On a press they can stop and wash the imaging blankets. Full bleed is achieved by running on oversized stock and trimming off excess afterwards. That is how the "Pros" do it.
Posted on Apr 27, 2009
taminol
  • 62 Answers
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Posted on May 26, 2009
  • 158 Answers
SOURCE: adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
Posted on Oct 03, 2009
Kevin Hayes
  • 167 Answers
SOURCE: what does code c-3101 mean on a bizhub c353
C3101: Fusing Pressure Roller pressure/retraction failure
hi,
open the fuser unit out of the machine and you may find that the gear which drives the fuser unit at the behind which retracts the pressure roller must have been broken. This gear is located at machine frame where the fuser sits
Posted on Jan 06, 2010
SOURCE: Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Posted on Feb 15, 2010
How do you fix code error 5102 on konca minolta bizhu c353
check the paper draws and registration assembly. or might have a burned out transport motor worse case main board
Jan 23, 2017 | Konica Minolta Minolta Bizhub C353 Copier
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
Error Code C-5102
C5102 Transport motor's
failure to turn
• The motor lock signal remains HIGH for a
predetermined continuous period of time
while the motor remains stationary
Some thing is binding the drive
Aug 22, 2013 | Konica Minolta Minolta Bizhub C353 Copier
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
Apr 17, 2012 | Konica Minolta Office Equipment & Supplies
Nov 12, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Sep 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub C353 Copier Logo
100 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
