Question about Fisher and Paykel Washing Machines
My Fisher & Paykel Aquasmart WL80T65D is not giving an error code but is saying "Hi efficiency and delicates/sheets" It wont fill up with water???? Have tried to get hold of a service manual. To
Top Loading 7.5kg Aquasmart WL80T65D does not flash an error code but it flashing on "high efficiency delicates/sheets. It will not fill up with water hot or cold. ????Please help
    Problem Solver:
  • 15 Answers
Check and see if this is the manual you need.
http://www.fisherpaykel.com/vault/pdfs/pdf_usecares/5002_NZ_Aquasmart_2_LCD_UG_lo.pdf
Posted on Jun 06, 2014
SOURCE: error code
just been told the code means heater failure. Just have to find out how to change it now.
Posted on Oct 29, 2007
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Washing machine filled with water but wont start, the spanner, delicates sheets and high efficiency lights come on after about 30 seconds, what could i look for
Fisher& Paykel have a lot of controls. But if it's filled with water and the lights are on, you have power to the unit. Try unplugging it, waif 5 min. Power it up advance the setting to drain/ spin setting with the door closed and try it again. What do you mean the spanner ?
May 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
What's your problem?hello i have a auqa smart washing machine WL80T65D and the service spanner comings up beeping continously. At the same time the sheet, delecate, and hight efficency buttons li
That is fault code 49,
But in AquaSmart machines the pump has shorted mosfets on the board and caused this to blow the fuse that controls the water valves.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
May 14, 2012 | Fisher and Paykel Washing Machines
My Aquasmart WL80T65D washing machine is telling me that it cannot lock the lid - but it is shut and appears to be in place.\r\n Does anyone have any suggestions for this?
Hi just read your posting.Does the machine stop and beep and show an error code in the form of lights on or an error code in an LCD display?Please reply with additional information and I am sure I can help you rectify the fault.Looking forward to your reply.
Oct 10, 2010 | Fisher and Paykel Fisher & Paykel Washer
My Aquasmart WL80T65D washing machine, stopped during a spin cycle and started beeping every second with a red spanner light flashing. I followed the manuals instructions to turn the machine off for a...
Hi just read your fault.Now from the information in your posting the lights that are on when the machine is beeping are the 3,4 and 8th lights.Now these lights are in a row of 8 lights and you started from the left.So from left to right the lights that are lit when the machine is beeping are 3,4,and 8.Is this correct?If it is correct then the fault on your machine is called COLD VALVE FAULT.The 3 reasons why this fault occurs is, 1st the wiring to the water valves is faulty,the 2nd is the cold water valve is faulty, or 3rd the control module is faulty.Have you or can you borrow an electrical test meter so I can help you narrow down which is causing the fault.Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Oct 04, 2010 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Jul 10, 2010 | Fisher and Paykel Washing Machines
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Washing Machines Logo
171 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
