Question about Bosch Axxis WFL 2060 Front Load Washer
Change fuses on bosch axxis - Bosch Axxis WFL 2060 Front Load Washer
2 Suggested Answers
uniman9310
  • 189 Answers
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Posted on Jun 03, 2009
Washing down comforter in bosch axxis
Well, it depends, there are a few solutions to this problem, and you can find most of them in the troubleshooter of the manual under this article:
Bosch Axxis Washer Manual
Jan 05, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis 2090 motor
If it's the motor, then you should definitely check the troubleshoter within the manual, you can download it under this article:
Dec 31, 2013 | Bosch Axxis WFL2090UC
Bosch Axxis WTE8600 F:09 error
That's a classical error which is connected to the software of the device, you have the whole error list together with the troubleshooter in this manual here, you can find it below the article:
Oct 22, 2013 | Bosch Axxis WTL 6508 Electric Dryer
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Fault code F18
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Oct 02, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WFL 2060 Front Load Washer Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
