Question about Canon imageRUNNER 1310 Copier
Prints 1 inch wide solid black band down one side
3 Suggested Answers
xptareq2000
  • 1447 Answers
SOURCE: prints band of black squiggles 1/2 inch wide down
Problem on your copier TD unite.Clean or service it.There are many parts,May be drum or drum cleaning blade is damage.
Posted on Jan 22, 2010
micromatikal
  • 2777 Answers
SOURCE: When printing with my Canon image Class MF 4350d
Strange, it sounds like the duplex portion of the printer is causing the issue. Did you add this duplexer after you purchased it, or was it part of the original printer? I think the d in 4350d indicates that it is duplex from the factory, but please confirm.
Thanks
Tim
Posted on Sep 28, 2010
The tv has two black vertical bands down the picture. one band is 3 inches wide, while the other is 1 inch. all other functions are normal.
Hi
This is not really a very simple fix but it can be done if you are ok with stripping down your tv, Please see the following video.
Hope this helps
Apr 05, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Prints band of black squiggles 1/2 inch wide down one side
Jan 21, 2010 | Canon imageRUNNER 1310 Copier
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Canon imageRUNNER 1310 Copier Logo
20 people viewed this question
old marine
old marine
