1. Open the door, remove the bottom rack and then then the lower wash arm and cover. The wash arm should be held by a large tumb trun. One you have the cover off, look for debris that may be blocking the wsh pump and drain inlet. After manu uses, sometime debris will accumulate.
2. If no luck, remove the front lower cover, find the attachment point for the drasin hose, remove the hose (out a shallow pan under it to catch any remaining water) and then unscrew (carefully) the check valve assembly. It's spossible something is stuck in the valve. When you reinstall it, do not overtighten it.
3. Of still no luck, it's possible the drain slinger is either plugged or worn. It resides under the pump impeller. Also check to see if the manual drain select switch works.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 16602 / 16604 / 16609
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed...
(More)
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed somewhere?
