Question about Dremel Tools & Hardware - Others
Dremel 3000 motor stuck - Dremel Tools & Hardware - Others
My Dremel 3000 makes a grinding noise and fluctuates speed while in the low speed range. Why is this?
I have one that I must keep pressing ******* the speed control with my thumb during use otherwise it is hopeless except at or near maximum. The potentiometer is of poor quality.
Jan 02, 2017 | Speed Washing Machines
Dremel 3000 just quit while using. it seemed as if it were unplugged from wall plug
try installing a new set of brushes in it i have fixed mine lots of times by doing just this !!! new brushes are sold where ever real dremel tools and bits are sold ck package back for your model number
Apr 19, 2014 | Dremel Tools & Hardware - Others
Dremel 3000 stopped
My Dremel 3000 suddenly stopped working also. No idea where the receipt was so i decided to investigate. I found one of the two stator windings had blown. I'd Barely used the thing, so that's the last dremel I'll be wasting my money on.
Feb 01, 2014 | Dremel Tools & Hardware - Others
Dremel MultiMax 6300 has stoped working Will not turn on.
Mine died also. It's the on off switch. Where can I get parts?
Oct 27, 2011 | Tools & Hardware - Others
The blade assembly on my dremel will not come off. Is there a trick to this?The coupling seems to stuck.
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Nov 08, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Motor works but no drive to shaft.
My 15 year old Dremel 395 had the same problem so I took it apart. There is a plastic spline between the motor and the output shaft to the chuck . My plastic spline was split and had many of its teeth sheared off. The shaft lock acts on the output shaft side of this spline, so it was ok. Otherwise everything looked great; bearings ran free & had little play free, brushes ok. To be fair, my Dremel had seen hard use & doesn't owe me anything. No luck so far finding replacement spline parts, which if available should be easy to install. To take apart your tool, just google "Dremel Disassembly". GOOD LUCK!
Nov 28, 2009 | Dremel Variable - Speed Multipro Rotary...
The motor on my dremel 395 works but the bit doesn't turn
there is a coupling between the motor and the spindle that has probably cracked or stripped out. I suggest going to Dremel.com and getting an original replacement part for this. They are not hard to install.
Sep 02, 2009 | Dremel Variable - Speed Multipro Rotary...
How does the blade move on the dremel motoshop 571-5? My motor seems to be stuck.
You need to have a blade installed... the unit locks itself when there is no blade
Aug 05, 2009 | Dremel Saws
Tools & Hardware - Others Logo
16 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
