Question about Whalen Furniture Furniture
Screws onto table top
Do the screws just screw into the table top?
SOURCE: missing screws
I had a similar issue and found the solution at http://productsamerica.com/page29.html I hope this is helpful to you and anyone else with similar issues.
Eric L.
Posted on Feb 11, 2008
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
SOURCE: What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Posted on Apr 27, 2009
  • 38 Answers
SOURCE: problem with top/low adjustment screws on shimano gears
Forget the screws as those are more for fine tuning once you are close to having it set correctly. Where the shift cable connects to the shifter on the bars you will typically find an adjustment knob (note that you may have the same type of adjustment knob where the cable meets the gear shift mechanism also) which the cable rides in. You will make much larger jumps in adjustment when using this method as opposed to using the screws located on the gear changing mechanism. Best of luck to you on the fix!!
Please be sure to rate this solution.
Regards,
Joe
Posted on May 08, 2009
wfservices
  • 260 Answers
SOURCE: 1995 ford f250 headlight assembly how to remove.it
REMOVAL AND INSTALLATION Headlamp Assembly Removal
  1. Remove radiator air deflector from radiator support.
  1. Remove two screws and two nuts retaining headlamp door (13064).
  1. Pull headlamp door from vehicle. Remove three bulbs and sockets.
  1. Disconnect engine control sensor wiring (12A581) from headlamp bulb (13007).
  1. Remove two retainers attaching upper two attachments of headlamp (13008).
  1. Turn horizontal headlamp adjusting screw (13032) completely out of the adjusting nut.
  1. Pull headlamp from vehicle.
Installation
  1. Follow removal procedures in reverse order.
  1. Tighten screws to 1.4-2.3 Nm (13-20 lb-in). Tighten nuts to 4-7 Nm (36-61 lb-in).
Posted on Sep 02, 2010
How do I clean the table fan? It is very dirty.
Remove the front grille with a phillips screwdriver, there are also two T10 Torx screws on the top and bottom. Wipe everything down with disinfectant wipes. Do NOT use water, with the exception of the front (dry it thoroughly). Don't remove the fan blades. Replace the front grille and screws.
Jun 25, 2015 | Honeywell HT-800 Table Fan
How do I remove the back cover from my flatscreen plasma TV?
Cover a table protective blanket.
Place TV face down on table.
Remove the stands legs( 2 screws each) then 4 large screws the legs attach to.
Or remove the wall mount brackets.
2 small black screws middle of the cover (above the component interface box).
Remove the component interface box, 5 small black screws , 2 on top, 3 on bottom.
6 black screws by the PC connection ports, (3 above, 3 below).
2 black screws on either side of the AC input plug.
12 screws around the perimeter.
Then the back should be able to be lifted straight up.
Aug 05, 2014 | Gateway GTW-P42M303 42 in. Plasma...
Toshiba 40BL702B lost table top stand screws
You can find the screws in your local hardware store.
Jan 17, 2014 | Toshiba Televison & Video
How do i remove the table top stand from my sony bravio model KDL-52V4100
Need replacement screws for my sony 52v4100..I lost the screws for the table top
Jan 28, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
We just moved and forget how to put the flat screen onto the table top mount??
Most the time they come with a plastic insert. If you put this in you must remove it and you will see the table top insert holes. Set the stand on something flat and have someone help you guide it in [properly then put the screws back in that you had remove to get it off. General rule of thumb is the table top stand will go straight into the bottom of you TV and may be offset to the back side of the television. Good luck finding the screws as this is the most common lost part.
Jun 21, 2011 | Samsung 50 in. Plasma TV
My fence is square to the table. How do I set the blade so it is square to the table? There is a 1\8" difference in the distance between the front and back of the blade in relation to the groove the miter...
I'm betting that the table isn't square to the blade. My Cabinet Makers Table Saw does the same thing - the top plate (the big heavy cast iron plate that weighs about 50 pounds) sits on top of the sheet metal box that houses the motor and motor lift. This cast iron plate is held onto the sheet metal box by 3 screws (usually).
Loosen the 3 screws and the cast iron plate can move around on top of the sheet metal box (the holes for the screws are large enough to allow 1/8 inch movement). Looking down from the top, you can rotate the cast iron plate clockwise and it will move the front of the blade closer to the fence and the back of the blade away from the fence. Counter-clockwise does the opposite.
For the best adjustment, use a dial indicator mounted to something that slides in the track of the table top. Position the dial indicator agains the blade and slide it back and forth in the track of the table top. This will accurately set the table top to the blad (so they are parallel within 0.0005 inches).
Then check the accuracy of your fence (sounds like this is good). Don't forget to check the alignment of your riving knife/guard & splitter to the blade (if it's off you can't feed wood because it will hit the splitter).
Oct 07, 2010 | Delta Machinery 3 HP Left Tilt Unisaw with...
I just bought a 42 inch table with oak wood supports. The screws are missing that hold the table top to the wood supports. The supports are held together with both screws and metal washers. I have found...
Washers, the bigger the better, will keep the screws from "eating" into the table, adding stability and preventing damage to the wood as you tighten the screws.
Nov 26, 2009 | Office Equipment & Supplies
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Drill Presses Installation
Here are a few instructions to follow while installing a Drill Press: Fix the column support to the base using the three screws provided. Slide the table clamp onto the column and align the table with the base and secure it in position using the table clamp lock. Place the head assembly onto the column and slide it down the column as far as possible. Align the head with the table and base and tighten the head locking grub screws with the hex key. Fit the depth scale. Attach the feed wheel. Secure the feed wheel in place with the cap screw using the hex key. Fit the chuck safety shield over the collar of the spindle nose and tighten the clamp screw. Carefully clean out the tapered hole in the chuck and the spindle taper using a clean cloth. Hinge up the shield. Push the chuck onto the spindle and lightly tap the chuck with a piece of wood to ensure proper fitting.
Aug 27, 2008 | Makita TW0350 1/2" Drive Impact Wrench
Furniture Logo
71 people viewed this question
Top Whalen Furniture Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Whalen Furniture Furniture Expert? Answer questions, earn points and help others
