Question about Electrical Supplies
Powamac series genset instructions - Electrical Supplies
How do i connect a spur Z Marklin engine shed to power.
if you are trying to connect a standby genset to house power, there are 2 ways to go about it
one is to have a 3 way switch in the house meter box and a caravan plug attached to the switch. This means that you have to physically switch off the mains power ,through centre point to get set power . using a lead to the caravan plug from the genset will then give you power to the house. You cannot have it so that the mains power and genset power are on at the same time
The second way is to have the genset connected through a mains operated relay where by when the mains power is off ( blackout) the relay closes for the genset and power is on to the house ( best with electric start gensets) When the mains power comes back on the relay changes over and shuts the genset off
Regardless of which way you want to go, discuss the options with an accredited electrician for best advice as it is not a job foe DIY's.
Feb 04, 2015 | Cars & Trucks
How do i do when some genset can't run togheter when we start the plant
im not sure are you asking about Phasing ? on a three phase gen set , yes extreme care needs be taken if you need to start one genset before shutting one off , in this case a Phase/sync meter will need to be used to keep from surging all the loads connected to genset , also all three phases of each genset needs to be "In sync" to be able to use a transfer from one genset to another , in sync refers to peek waveform on each genset, needs to be in perfect time or an "ARC" will occur , that could be detrimental to the connected loads if there sensative to this type
Jan 18, 2015 | Electrical Supplies
No power on Cyclone 4100
Do you have power at the outlet where the unit is plugged in? If not restore power to that point. Next, check the main breaker to determine if it has tripped. It may look like it is on but to verify, turn it off and then back on. It should click into place. If that does not work and your trailer has a genset with a transfer switch. Check the transfer switch to make sure that it has not failed. It may be locked into the genset side and not switching back to shore power. If you are running the genset and do not have power make sure the breakers on the front of the genset are on.
Mar 02, 2014 | Heartland 2012 Cyclone 4100 KING
I have a 1997 onan emerald series GenSet 6500 I have been thru 4 starters it keeps breaking the drive gear assmbly WHAT CAN I DO PLEASE ITS ALREADY COST ME 400.00
Have you replaced the solinoid too? If not, maybe the solinoid is staying engaged, which keeps your starter, well starting. If the starter stays energised the flywheel WILL tear up the starter gear.
hope this helps
Nov 04, 2010 | Watts Onan Portable Generator - 5000 ,...
Hi I have a Tripplite 3636VR connect up with 3 X 200AH batteries in series. The inverter works fine when connected to city power, when the city power fails the inverter takes over noramlly, I then go and...
check the system but you may have to turn off the batteries
the inverter is charging the batteries but when mains power fails , the batteries will be discharging back through the inverter that is dc converted back to ac
if you power on a genset and the ac is not phased correctly, what you describe will happen--- inverter ac from the batteries against genset ac to the inverter-
If you had mains power on then it would dead stop the genset because of the out of phase situation
it all has to do with the 2 wave patterns for ac current from each unit being in harmony and not working against each other
Mar 19, 2017 | Tripp Lite PowerVerter APSINT3636VR UPS...
My pressure washer starts on the first pull but shuts off right away.how come
the carb is dirty, drain the carb bowl sump, then if your lucky get fresh gasoline and clean and refill the gas tank,also get a spray can of carb cleaner into the intake from the parts store and while running & gently spray into intake as not to kill engine,this may help then fresh gas can finish cleanout, otherwise the carb needs to be replaced and being a genset most dont sell a rebuild kit, and are sealed so as to keep rpm's constant on a genset for voltage output and safe levels of power output
Nov 08, 2009 | Briggs Stratton 020273 Elite Series...
Engine runs but no power aat outlet????
Start with brushes and rings. Make sure your rings are clean and the your brushes have a good length. Flash the fields with 12V battery. Apply positive to the brush nearest the bearing and negative to the back brush, while genset is running. Use rubber gloves when doing this and keep hands away from rotating parts. You should see the voltage climb when you flash the fields. This would mean that you need a voltage regulator. If voltage does not climb, then you will need a new genset.
May 15, 2009 | Coleman Electrical Supplies
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Apr 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
12 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
