Question about Nintendo DS Console
Nintendo DS Lite: shuts off every few minutes, new battery...
Hi... This DS Lite has always been fine. Then it started shutting off after a few minutes of play. So we got a new battery for it. Same problem. The power light is green on the charger and on the DS when in use---but it shuts off anyway.
  • 2 more comments
  • Jeff Potter Oct 26, 2007
    "Only chargers work"---how?
    We changed the battery. The old battery would go to red in the DS then we'd plug in the charger until it was green. Then the DS would show a green power light and it could be played...for a few minutes...then it would die. So we got a new battery. It was green to start---pre-charged, I guess. The DS power light is always green. The charger light is green. The battery seems to be fine. The DS still quits after a couple minutes.
  • Jeff Potter Oct 30, 2007
    We tried that. It is now shutting itself off sooner than before. With a green-light, fully-charged, brand-new official battery. I suppose we should mail it in. But I was hoping there might be an operating-system reboot, rebuild command we could try.
  • BEEDad Nov 28, 2007
    My son's DS Lite also has a shutting down problem - right after turning it on. Based on the comments of others, it sounds like a new battery won't fix it. When it is plugged into the wall and powered up, it stays on for about 10 seconds before shutting down.
  • al999 Dec 08, 2007
    I have the same issue, but oddly it seems to occur more with certain games, and less with others. Mario Kart works fine, whereas Tony Hawk's Proving Ground switches the machine off after a random amount of time. Battery is full.
  • 38 Answers
If its the same as the ds it could be the contacts for battery either popped out or are squashed in take battery out and examine battery contacts carefully sometimes you can carefully poke them back into place with a small screwdriver,only do this if your sure they dont look right and are out of place
Posted on Nov 05, 2007
Your supposed to charge it until the light is off
Posted on Oct 27, 2007
When you say you've changed the battery do you mean actual batteries or a charger. Because only chargers work
Posted on Oct 26, 2007
Hi there My DS Lite has started to turn itself off straight after being turned on and its fully charged. It has had a new battery and I have got a brand new charger and the DS lite when turned on, turns...
Hello there,
Unfortunately, something may be shorting out at the hinges causing the DS to shut down automatically. It is probably a ribbon cable damage. Try contacting Nintendo to try to get it fixed.
I hope this helps! Thumbs up are always welcome.
May 03, 2011 | Nintendo DS Lite Console
Nintendo ds lite that shuts off unexpectedly
Hi again,
Ive been doing a bit of research and it seems that if the DS lite has had a knock the black coil near the power switch could have been knocked loose which would make the DS lite switch off randomly. If you want to see if thats the problem take the DS lite apart (for a dismantle guide click here) and check to see if its loose... its the black round thing with 100 written on it near the power switch. If its loose then heat up the solder round it and that should reset it.
If thats not it check the L2 transistor is firmly in place, again if its loose heat the solder and reset it.
Another thing you can check is the power switch make sure its solid and doesnt wobble internally i.e. the black moveable part only moves the way its supposed to, as well as checking the solder is solid.
Hope this helps, if it doesn't sort out your issue then get back to me and I will continue to help you.
Jan 04, 2010 | Nintendo DS Lite Console
Power shuts dowd
the battery is not charging correctly or has a fault contact nintendo
Aug 06, 2009 | Nintendo DS Lite Console
Nintendo DS shuts off randomly
try to play with the poweradapter connected. If the problem still there you will need probably a new mainboard for your nintendo. If the problem disappears probably a bad battery is the problem. If you can exchange your battery with another NDS lite you can check if it is the battery or mainboard.
Jul 06, 2009 | Nintendo DS Lite Console
Nintendo ds lite shut down
I would contact nintendo if you have a warranty. Also try changing the battery or charger on the internet
Dec 03, 2008 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on
My kids did the same thing. What I did to get it to work was to push back on the top and hold it turn it on. If it comes on then turns off after you let it go get 2 rubber bands and put the 1st. one on the top left down to the bottom right. The 2nd. one goes from the top right right to the bottom left. Then keep turning it on while moving the top to find the sweet spot.
Jun 03, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
268 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
