Question about Rowenta Steam Generator DG050 Iron
Brown streaks coming out of the steam holes on rowenta DG580
DiYerTech
  • 70 Answers
SOURCE: steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Posted on Jul 02, 2008
DiYerTech
  • 70 Answers
SOURCE: CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Posted on Jul 26, 2008
  • 341 Answers
SOURCE: My Rowenta iron is giving
fill with limeaway let it sit for about 2 hours.. empty.. fill with water
Posted on Oct 22, 2008
brnspncr
  • 67 Answers
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
heatman101
  • 43501 Answers
SOURCE: ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
My Rowenta iron was working fine the last time I used it. I plugged it in to use it today and nothing. The little red light on top comes on but the light on the side to let me know it is ready and hot...
Yes there is a solution, I have a DG580 with the same problem. I had to replace the electric cord which cost $17.00 and took 30 min to replace and now works like brand new.
Steve
Dec 02, 2010 | Rowenta Irons
I purchased a rowenta 1600w effective iron about 3 months ago and now everytime I iron after I plug it in the light for steam won't come on and if it does it doesn't even stay on steam for me to finish a...
Possible that there is corrosion inside the steamer unit . The best is to keep filling and puttingthe set on till the dirt ceases to come over.
It can be due to even some foreign particles that is lodged in and making is combine with steam to produce the dirt colour.
If you can use a flexible bowden to clean into the holes just to see if there is any block it will be useful.
Sep 09, 2010 | Rowenta Irons
Brown spots coming from steam iron
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Jun 23, 2008 | Oreck Cordless Speed JP8100CA Iron
Brown gunge and white deposits keep coming out of the steam holes on the sole plate. We have tried de-scaling but it has had no effect. This iron has had very little use since we bought it about 18 months...
Try filling full-strength white vinegar instead of water. Then allow to steam out on scrap cloth. The white deposits are likely to be calcium. The brown gunge may be rust. When the deposits are minimized, use only distilled or bottled water from then on.
Mar 15, 2008 | Rowenta Perfect Iron
Rowenta Steam Generator DG050 Iron Logo
59 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
