Question about KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender
Dishwasher doesn't fill and spin - KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender
  • KitchenAid Master
  • 1,317 Answers
Try asking this in the dishwasher department, asking it in the blender dept will invite unhelpful replies like this 'cos I know nuthin' about dishwashers.
Posted on Jul 26, 2014
Why doesn't drive shaft spin?
might be the start switch in the motor and or a capacitor. it should turn fairly freely by hand, if not it could be a bad bearing/bushing.
May 08, 2014 | Robot Coupe "R2 DICE - Combination Food...
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
My GE Potscrubber 950 dishwasher is making a lound grinding noise when I turn it on. The noice continues through the entire time that the dishwasher is on. It does still get my dishes clean but the noise...
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the spraying arm or the pressure pump can be defective .It is important that you look for the noise with a good inspection lamp. Manually turn the spraying arm and the motor and listen for the noise, if so the motor bearings, the arm shaft and fittings must be checked. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of spraying arms check for tips on this visual link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Thank You for using fixya
Aug 24, 2011 | GE Blenders
I was blending a slightly thick batter and the Vitamix just stopped! Will the machine start after awhile? Do you think it has just overheated? How do I find out ? My old Vitamix had a reset button at the...
Well it might just be over heated, let it cool for approx 20 minutes then restart if it doesn't then u may try switching electrical outlets, if that doesn't work then it needs to be replaced. I hope that this helps, if not please let me know and i will try and help you out as much as i can.
May 28, 2011 | Vitamix Super 5000 Work Top Blender
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
I have the blender and I'm not sure if I want to put it in the dishwasher. Is it dishwasher safe? If not, how do you appropriately clean it? It doesn't come apart easily. I just need to know how to clean...
We put the top part of aur bleander through the dishwasher all the time... no problems....just take it off of the base and unscrew the chopper from the jar...throw the little parts in the utensil cup and you are good to go...
heatman101
Aug 07, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart fpb-5ch blender not working
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
Dec 11, 2008 | Blenders
KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
59 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
