Question about HP Photosmart 5510 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan
My hp photosmart printer won't print red, even though I changed ink cartridge
JoshOHoward
  • 63 Answers
SOURCE: hp printer 1020
Hello FixYa User,
If you are using thermal paper, Turn the roll upside down (I had the same problem).
If you don't use thermal paper please ring HP on 1 300 888 423 they will tell you whats wrong for free, If the Facsimale is faulty and is under warreanty they will fix it.
Hope this helps!
Posted on Jan 29, 2008
checkitright
  • 1362 Answers
SOURCE: HP 1040 fax change ink cartridge
here is the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=02c3572ff6a11ac342ae55fe4e15c1a2&q=hp+1040+fax&e=1
Posted on Jul 15, 2008
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
leroyal
  • 2120 Answers
SOURCE: Message: Intall new ink cartridge. Ink Low
When you hear the fax ringing, press the start button. It sounds like you are not set to AUTO RECEIVE
Posted on Jan 24, 2009
  • 106 Answers
SOURCE: Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Posted on Feb 16, 2009
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
My hp photosmart c 3180 will only print in black even though I have a full color ink cartridge. How do I print in color if i'm using a mac?
Hi, Go to the printer settings and select colour printing option. Before that make sure that the cartridges are not blank or not get dry.
Sep 27, 2011 | HP Photosmart C3180 All-In-One InkJet...
Won't print black ink
Try to print with other colors. Change the font color to red. If that printed, then you need to change cartridge for the black ink.
Jul 12, 2011 | HP Photosmart Premium C309A All-In-One...
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Will not print black
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 5510 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
