Question about Crafts & Hobbies
1130 engine light, but will not go
I have 14 volts getting to the track from both a Type 1033 and another smaller transformer. Engine will light up and hum, but will not move
5 Suggested Answers
SOURCE: I have a Multicontrol 115 volt transformer (4
I went to a train dealer.
Posted on Nov 21, 2009
SOURCE: I have an HO scale
Check the engine motor and second car motor with a digital multimeter for continuity. Make sure the track is connected properly. Also probe the transformer and see if it is sending out power to the track
Posted on Dec 20, 2010
  • 38 Answers
SOURCE: Ι've just joined 2 ovals
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Posted on Jul 23, 2011
residentoccu
  • 161 Answers
SOURCE: my f3 santa fe only runs in reverse with my 1033 tranformer
try reversing your wires from the transformer to the track.
Posted on Mar 02, 2013
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
My f3 santa fe only runs in reverse with my 1033 tranformer
Dec 29, 2012 | Lionel New Haven Freight Train Set
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Check engine light came on as my volt gauge went from 14 to 11
check wiring loom to alternator,bat connections or lack of volts from alternator
Jul 03, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
I am trying to hook up a Lionel 1033 transformer to my Christmas train. What terminal goes to what? I want my old 2026 to smoke and my 6446W to whistle.
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Dec 14, 2009 | Toys
Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
1996 jeep cherokee country
Sounds like the starter is going out. Autozone will check those for free. It's just 2 bolts mounting the thing. It's under the passenger side rear of the engine. Undo battery, those 2 bolts and keep track of which wires go where. Run down to Autozone for a check or a new starter.
Oct 26, 2008 | 1996 Jeep Cherokee Country
Crafts & Hobbies Logo
24 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
