Question about NetGear Computers & Internet
Netgear dm111psp won't connect
Won't connect to internet
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
Set up my netgear router. laptops show that they are wirelessly connected to the main computer, but we cant get them to connect to the internet. also lost the netgear cd that came with router. do we need...
The netgear router installation will set up the internet connection during install.
Download the Router driver from netgears website and install on the computer/s then your up and running.
it appears you wireless card is seeing the router so just install the drivers and your set.
Oct 03, 2010 | Computers & Internet
Netgear power is connected, but internet is not
If the router has no power you cannot connect to the internet.
If you have an internet connection then you are connected to someone else's router.
May 19, 2010 | NetGear DG834 Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
Wireless connection
re-installed the netgear driver properly you get it
Jun 19, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection problems
If Internet sharing is set up correctly one pc will be the one that connects directly to internet, the other will connect through a gateway or other device connected to your network. Check they have'nt both got the same IP address. Is this related to last problem, did you get the wireless card working wirelessly online?
Nov 20, 2006 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
42 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
