Question about 473v Viper Remote Case Three Button
How to program a ezsdei474 remote to a viper 130xv
How do I program my viper replacement transmitter for my car.
Dear Marta,
Here is a hands on to watch and program as you go. Follow to the link. How To program DEI Viper Python Avital Sidewinder Valet Hornet Alarm...
Here is another look. 1f Responder LE Remote Pairing
For your direct contact to Viper follow this link for any question. Viper Support
Fare. Well.
Dec 12, 2014 | Viper Vehicle Parts & Accessories
How to program a ezsdei474v to a viper 130xv
you're going to have to call the manufacturer to get those answers.
Feb 08, 2014 | Vehicle Parts & Accessories
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
Program remote
get in vehicle turn key on with new key fob in car, let run for 20 or so then turn off . hit the unlock button it should be programmed but not promising anything lol
Sep 30, 2013 | VIPER 7141V VIPER 4BUTTON REMOTE 7141V
How to take my viper remoter off vabration. a where can i find the manual for the viper remoter
To enter programming mode Press the Program button on the back of the remote or hold the four remote control buttons on the front of the remote simultaneously until one long beep is heard. Programming Mode has now been entered.
Beep/Vibrate Mode Within five seconds of entering Programming Mode, press Lock. The remote control will beep once for on, twice for off. The vibrate icon (13) will also turn on/off with each press.
Here's the owners manual for that system: http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
remote programming starts on page 15.
Mar 25, 2011 | 7701V Responder SST Remote
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I need a instalation guide for a viper130xv remote starter
I can email it to you. My email address is solomonsfinest@aol.com. Put Viper 130XV in the subject line
Sep 15, 2010 | Remote Start System
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper starter and car alarm with 2 controlls and one got stolen what should I do
The Viper alarms will accept (if I remember correctly), 4 codes at one time. That is, 4 individual remotes, or two remotes two times, or one remote 4 times. So, if you program your remote 4 times, it will essentially remove any previously programmed remotes. Another option, and you'll have to check with your dealer, but I think there is a way to delete ALL remotes, and then program your remaining remote one time, and again, all previously programmed remotes are now removed from memory. This was done by the manufacturer just for such events.
May 17, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
473v Viper Remote Case Three Button Logo
49 people viewed this question
Top CAR Plus Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CAR Plus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
