Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
My amana PTAC won't heat, the heating coil looks good, what else should I try?
2 Suggested Answers
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
PTAC PDE12K3SB - No Heat
i think so may be the heating coils are not getting heat without power supply check out the plug in wire and whole supply.
Dec 18, 2007 | Friedrich Digital PTAC PDH12K35B Central...
Amana PTAC unit when in the heat mode only blows cold air.
check heater coil may be faulty may be a faulty thermostat or temp sensor
Dec 08, 2010 | Amana Heating & Cooling
Ptac has been in sun room for about 3 years. Turn on heat and it only blows cold air.
May be your thermostat setting wrong. If corrected check the heating coil.
Dec 06, 2010 | Amana PTH123B25AJ Heat Pump Air...
I have a amana ptac through the wall unit. the evaporator keeps freezing up on me. what is causing this
several things could be the cause but lets start with the easiest first. check the filter to see if it is clean. if so then you need to see if the coils behind the filter are clean. a blockage of air flow will cause the unit to freeze up. If the coils look dirty then you can purchase a coil cleaner (aerosol) from a home improvement store or an a/c supply house and follow the directions on how to clean. These coils should look nice and shiny. If all of the above mentioned are in good shape then you possibly have a low charge of freon in the system. In that case an a/c tech will bee required since the usage of freon is only to be done by certified techs.
Hope this helped
Dave
Feb 21, 2010 | Amana PTC093B50AJ Electric Heat Air...
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
Amana ptac constantly freezes changed board with dsuko1c kit
in heating mode find sensor located on coil follow to board connection usually 24v and dft terminal jump out with a wire and jump test pins if goes into dft then sensor bad if not board
May 11, 2009 | Amana PTC093B50AJ Electric Heat Air...
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Nov 18, 2007 | Amana PTH123B25AJ Heat Pump Air...
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
32 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
