Jayco eagle premier 2013,
Where is the relay module for Learning my remote transmitter part number gs-xmtr-01
3 Suggested Answers
bschilz
  • 2049 Answers
SOURCE: Serp. belt replacement '91 Eagle Premier
Here's a link to the diagram...
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S8003
Here's a link to a video on how to replace your serpentine belt...
http://www.wonderhowto.com/how-to/video/how-to-change-a-serpentine-belt-on-your-car-39904/
Posted on Sep 04, 2009
  • 194 Answers
SOURCE: pulley tension diagram for a 1991 eagle premier
try going to autozone website they have lots of good stuff for you to look at and print out
Posted on Nov 20, 2009
Changing pin number on my genie garage door remote
The step by step programming genie digital remote transmitters with internal set switches.It can be controlled by radio controlled transmitter and by wall mounted key pad.
Jan 04, 2018 | Building Materials
03 Lincoln Navigator - No Door Locks, Auto Lights - Already used process of elimination - missing something - Help!
Simple fix; bring the vehicle to the dealership and let them reprogram the system!
Feb 21, 2017 | Ford Cars & Trucks
I need blueprints for JAYCO EAGLE PREMIER 371FLFS 15FW
jayco.com they have the bluprints you need. search their database
Dec 22, 2016 | RVs
I NEED WIRING SCHEMATICS FOR MY 2001 JAYCO EAGLE FIFTH WHEEL 34' TRAILER
Contact jay co direct on the net for what you want
Apr 12, 2015 | Cars & Trucks
Power lock
check door locks fuses and relays.if all is good and you cant operate door lock buttons manually problem could be in the generic electronic module.if door locks dont work from the remote battery could be dead in remote transmitter.try to reset door locks control module first obtain all remote transmitter.sit inside vechicle with all doors closed.switch ignition from off to on 8 times in 10 seconds. doors should lock then unlock.when this procedure works then press any button on any of the remote transmitter doors should lock and unlock.if all fails let dealership fix..
Dec 27, 2012 | 1998 Ford Windstar
1989 eagle premier head light switch is not turning on head lights just the park lights but when i pull the arm for the high beams i get them as long as you kep holding it checked fuses and relays
The fault can be with the cluster switch as the HIGH BEAM is switched and so the relay is working. The failure of the switch contacts of the main which is the park along with the headlights is to be confirmed.
If you are able to carefully JUMP the +12 from the headlight switch position and if the lights work the fault is confirmed.
Oct 03, 2011 | 1989 Eagle Premier
2000 ford windstar power door locks do not work and have checked every fuse
The actuactors for your locks have a little motor in them. In this motor there is a resistor that will give out over time. Usually the locks gradually stop working over time. You can remove the actuator and take it apart and fix by removing the resistor in the motor and putting a peice of copper in its place. Takes about 30 minutes per door if you know what you are doing. Do a google search for ford windstar door lock fix and you will find several blogs with detailed descriptions of the repair.
Jul 02, 2009 | 2001 Ford Windstar
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
