Question about Refrigerators
Hotpoint ffp187b f/f motor sounds like its running light works but no cold air
  • 159 Answers
SOURCE: hotpoint iced diamond fridge just stopped working
firstly change the thermostat
Posted on May 15, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have an old Hotpoint refrigerator. My problem
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Aug 31, 2009
milten1
  • 1304 Answers
SOURCE: runs, light works, no cold air.
since everything seems to be working,
lets start at the beginning.
pull the unit out and remove the back.
is the compressor running,, becareful, but touch it with you hand. if its cold,,
unplug the machine
you may have a bad relay or overload,
they are the parts that are mounted directly to the compressor.
if you can remove it and give it a shake if it rattles
its bad, not allowing compressor to come on
thats where id start,,, let me know
Posted on Oct 12, 2009
dmftrucker
  • 1922 Answers
SOURCE: FRIDGE LIGHTS ON, FAN MOTOR RUNNING. NO COLD
you need a new RTX contactor on the compressor body,the compressor isn't operating
Posted on Dec 24, 2009
mechboy6000
SOURCE: hotpoint ffp187b loud noise from appliance
Where is the noise coming from? The front, back, top, or bottom? Is it a bump, thump, bang, clang, or rattle? Does the sound happen at regular intervals or randomly? It could be the compressor bushings going bad, causing the compressor to bang around.
Posted on Mar 25, 2013
Hotpoint ffp187b
The temp sensors, or thermostat may not be correctly reading the temperature. if the temp sensor reads the wrong temp for example it'll think its warmer than it actually is and keep running to try and satisfy the tstat.
Aug 05, 2013 | Refrigerators
Hotpoint ffp187b loud noise from appliance
Mar 25, 2013 | Hotpoint Refrigerators
We have a Hotpoint Side by side- Freezer is working but the Refrigerator is not getting cold - What to do??
There is a couple of things that could be going on here.
1. Open you freezer door look at the back panel and see if it is covered in ice. If it is you most likely have a defrost issue. If this is the case the Evap coil becomes covered in ice to the point it does not allow any air flow.
2. Open freezer door and with one hand push in the door switch so the light goes off. Listen and feel to see if the Evap fan motor is running. If it is not running we could have a bad fan or a bad board.
3. Open you fridge door, in the top left portion of the should be a damper assy. put your hand in front of this damper and fee for cold air and some air movement.
After you have done these three things I walk you a little further in solving your proble,
Sep 01, 2011 | Hotpoint Refrigerators
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Aug 30, 2009 | Refrigerators
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
