Question about Dryers
Lce752l-w-3 cant figure out how to change the belt on washer
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Belt replacement on a frigidare stacked dryer
Check the below link :-
http://repair2000.com/wpoolbelt.htm
Paste and copy it in other browser and click enter.
Any further help, let me know.
Thanks for using "Fixya"
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Jun 01, 2009
Cant figure out how to tighten the belt
Some front load washers don't have any adjustment at all.the motor is fix in one position.to put a new belt on can be quite difficult,you just have to try & wined the new belt on.it will be very tight.
Jun 04, 2010 | Washing Machines
Hello, I am replacing a 15+ year Frigidaire
these are usually 220 volts.If the grey cord has three prongs on it it will be 220.
Mar 17, 2010 | Frigidaire FEX831CS Top Load Stacked...
Im trying to figure out what is all in the timing belt system on a 92 sunbird. Its like the 3rd one down???? im thinking its the water pump but im not exactly sure and i cant find any diagrams on it.
After 2 belts you should know about how to set the timing marks. With a 17 year old car, the water pump bearing and the belt tensioner are probably worn. They are the cheaper of the items on the belt. If you have A/C remember if it was on the last 3 times the belt failed. I would not suspect the alternator unless you replaced each one shortly after the belt broke.
If you have A/C, the compressor could have momentarily frozen if too much moisture is in the system.
A backfire can cause the timing to jump and will bust the belt. There have been several people on Fixya with similar cars driving along just fine and for no reason the belt pops. Get a good brand of belt and if somehow possible you see a date on it- go for a newer one that is not dry rotted hanging on a shelf somewhere.
Finally, check the alignment of the pulleys which would be the A/C and Alternator. One misplaced washer can change the track of the belt.
Jul 02, 2009 | 1992 Pontiac Sunbird
Jun 01, 2009 | Frigidaire Dryers
How do I change the washer belt on a Maytag Washer #LAT2500AAE
I figured out that the belt went on the bottom of the dryer. It was actually very easy to fix once I realized where the belt went. I made the mistake of opening the front cover of the washer first, which is why I did not see where to put the belt. Apparently, if the washer is not level (since I had too much for a load and it caused the washer to pull out from the wall), the belt shook itself loose.
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
How to loosen the serpentine belt
If you look at the spring tensioner on the belt, there is a 3/8 square hole in the support arm.
Use a ratchet wrench, or breaker bar in the hole, and release the tension. Once it's loose, you can remove the belt.
Oct 17, 2008 | 2003 Pontiac Grand Am
Putting belt on top load amana washer moder #unknown
There is a large pulley directly under the washer drum that runs the transmission. There is a small one connected to the motor shaft, and a third which is attached to a spring-arm and acts as a tensioner.
Pay attention to the direction the tensioner moves. The back of the belt should go against the inside of the tensioner when it is released.
The easiest way I've found to get the belt back on is to thread it around the small pulley, and tensioner, then start it on one side of the large pulley, and rotate the large pulley to allow the belt to thread onto it.
Hope this helps.
Aug 13, 2008 | Amana NAV5805A Top Load Washer
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
12 people viewed this question
Top Dryers Experts
