Question about GE JE1540 Microwave Oven
Ge profile microwave je2160sf01
I used a volt tester on the curcuitboard relay switch terminals. No power was detected when oven turned on or off. Makes clicking sound, but no lights, fan or magnatron powers on. Got new magnatron 1 year ago. Do I need a new curcuit board? Thanks, Paul
MicrowaveSvc
  • 9085 Answers
SOURCE: Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 09, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Jan 09, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
SOURCE: Microwave turned on but nothing inside to cook, so now it's dead!
Put him up for adoption before he burns down your house.
Posted on Jan 29, 2010
How do I remove the front control panel on a ge profile je2160sf01?
On most over the range ovens, the screws for the control panel are on the top of the control panel. You usually have to remove the air deflector above it to acccess the screws.
Dec 24, 2016 | GE Microwave Ovens
I have a GE JE2160sf01 Microwave oven. The oven blew the bulb and I have replaced it. Since replacing the bulb, the turntable will not rotate. I have checked and replace the motor, but still have the...
If you replaced the motor and turntable still does not rotate, either the motor is not receiving power or the the drive that turns the tt is not working because of slippage, etc.
Nov 08, 2015 | GE Microwave Ovens
I need to replace the frame that goes around the microwave because it has so many scratches, where can I get one?
You can find helpful exploded views and order parts by entering your full model number (JE2160SF01) at the Pros' site here.
Mar 20, 2013 | GE Microwave Ovens
Light stays on
Possible that the door switch is stuck or that the relay is jammed within. Remove the power and gently tap on the door switch and the relay on the PCB.
If there is no result and if there is no switching of the microwave unless the door is closed , then problem can be due to the control board.
Jan 11, 2013 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL1800
pull the cover off of the microwave and check for anything loose. ie fan bracket covers. check the 4 nuts that hold the magnatron in also. if that doesn't fix it maybe you can go to an appliance repair place and see if that have a magnatron tester which is just a piece of plastic with 4 bulbs in it and if the magnatron is working properly with that tester in the it will look like a red strobelight going off in the microwave. if not then your rumbling noise is the magnatron getting ready to go out good luck
Dec 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
