Question about Konica Minolta X300 35mm Film Camera
X 300 minolta can't wind on film - Konica Minolta X300 35mm Film Camera
Can i use tamron 90-300 mm af macro on my minolta 404 si dynax ?
Tamron makes lenses with a variety of lens mounts. If the lens has a Minolta mount then yes, you may use it with your camera.
Sep 21, 2013 | Konica Minolta Minolta Dynax 404 Si 35 Mm...
Minolta Maxxum 400si is locked up
link to your manual, it tells us that we have a winding motor problem, I would do as you have done, so I would ensure that batterys are in great shape, the only other thing I could suggest is to try to turn the winding motor by hand in case it is just locked up. Failing that I presume the motor has died and needs replacement.
Dec 05, 2007 | Minolta Maxxum 400si 35mm SLR Camera
How do you open the back of a minotla gx-a film cam
On the left of the camera is where you power it on, and wind the film. pick up on the silver part of the film winding mechanism. That should pop opent the back. Hope this helps!
Apr 01, 2011 | Minolta XG-A 35mm SLR Camera
1) Minolta XG1 35mm Film Camera 2)Minolta X300 35mm Film Camera Which batteries can I use for the cameras listed above?
XG1:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent).
You can download a copy of the manual at
http://butkus.org/chinon/minolta/minolta_xg-1/minolta_xg-1.htm
X-300:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent), or one 3v lithium (CR-1/3N).
http://butkus.org/chinon/minolta/minolta_x-300/minolta_x-300.htm
Feb 17, 2011 | Konica Minolta X300 35mm Film Camera
Film is not winding on fully
Possible that the loading motor is having friction to load fully or that the film reel is too tight.
You can check the test without the film in place but by activation of the door switch.
If the reel pressure is good ,then the film reel might be badd or if the hand pressure stops the reel then the motor might be weak.
Hope the battery is charged. if not used recently let it run winding up to free.
Sep 19, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Help with minolta x-300s, i cant seem to move the film winder
Well, here's the most likely things going on:
1. dead battery. Your X-300 has an electronic shutter that needs battery power to work. Try fresh batteries and check the battery contact wires for corrosion.
2. End of roll. If you have film in it, try the silver button on the bottom. rewind film and try another roll of film. Before you put in the new film, try the advance, click, advance, click thing.
3. Not all rolls of film are perfect. Some are shorter than they should be, some hang up in the canister.
4. The Minolta X-series were well known to have a problem. Two cheap capacitors on the later models would die, locking up the camera. One is under the top plate and the other under the bottom plate. These caps need to be replaced. I suggest you send it to a repair shop for that. Check prices. Garry's camera repair in Niles, IL does a very economical repair on these. It runs about $50 and $8 for return ship. He will also Clean, Lubricate and adjust it.
You could also buy another 300/370 on Ebay, as they're inexpensive these days.
Best of luck. Hope its just the film or batteries. You might also consider joining the Yahoo Minolta groups.
Jan 19, 2010 | Minolta Photography
Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Aug 05, 2009 | Minolta X-370S 35mm SLR Camera
Minolta X-9
Mar 22, 2009 | Minolta X-700 35mm SLR Camera
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Konica Minolta X300 35mm Film Camera Logo
42 people viewed this question
Top Konica Minolta Photography Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
