Question about Zodiac Clearwater C250 Electrode Kit
Fuse size for c250 clearwater chlorinator - Zodiac Clearwater C250 Electrode Kit
Zodiac LM2 Chlorinator. Super Chlorination light comes on, no other buttons work. Unplug and plug back in with same effect.
there is a 'secret' reset button located toward the bottom left of the control screen. if you run your finger around the zodiac symbol, you will find the indent where the button is located.
you will see all the lights go off and then light (or the other way around) as it resets.
make sure the leads are all connected.
if this doesnt work, or stays the same, remove the cell and inspect where the leads hook up to see if one has burnt off inside the cell. sometimes, you have to clean the cell to see it properly
Jun 20, 2014 | Zodiac Clearwater Lm2-24 Complete Salt...
Broken electrode on outside . Chlorinator not producing chlorine
check cell for calcium and replace cord with cell also check sensor
Jan 10, 2013 | Zodiac Clearwater Lm2-24 Complete Salt...
How do you set a pool chlorinator timer - pump wont go on automatically and I dont have a user manula for my clearwater LM2 24TS
If the timer does not keep the time of day then it is faulty and needs to be replaced.
Timers have adjustable tabs to turn the timer on and off at a set times of day.
Dec 02, 2012 | Pool & Spa
Lm2 unit. No chlorine output. no flow light is on but dim. super chlorinate light is on.
check voltage at cell if high cell might be shorting out or transformer going out
May 20, 2012 | Zodiac Clearwater Lm2-24 Complete Salt...
DuoClear 20 can't get salt light to go out unless
I have a Duoclear 25 for 3 years now. The unit has been nothing but trouble. I too have a low salt light even when the pool is tested at 4500ppm. 4500ppm for our taste is too high. The main board has been replaced for erroneous errors and now one year later the salt cell generator is non functional. The quality is poor. Furthermore most pool stores don't even know how the nature 2 works and alwasy recommend chemicals that are harmful. The company Clearwater has poor customer service.
Aug 25, 2009 | Zodiac Duo Clear System Chlorine...
Zodiac Clearwater C250 Electrode Kit Logo
41 people viewed this question
Top Zodiac Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Zodiac Electrical Supply Expert? Answer questions, earn points and help others
