Question about Whirlpool GH5184XPQ Microwave Oven
Whirlpool fies error - Whirlpool GH5184XPQ Microwave Oven
Whirlpool gh6177xpb microwave error 252 on touchscreen at startup. How do I fix
clean ribbon cable that goes from pad to control board with denatured alcohol undo lock unplug cable clean contacts
Nov 23, 2014 | Whirlpool Microwave Ovens
My whirlpool microwave oven will not power up and shows a code f2. how can i fix it
its an error need to call technical assisstance ..thAT error ranges for faulty temp sensor/probe up to control board ....
Aug 05, 2014 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
Error Code F8E5?
see if the place you bought it wants it returned for refund and you might get some assistance.
Sep 03, 2012 | Whirlpool WMH31017AW
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
My new Whirlpool Microwave oven is now showing an F7 on the screen and will only turn on for 3 seconds. What should I do?
Hi and welcome to FixYa, I am Kelly.
The F7 = HV SMPS feedback error. Most of the time this is a costly microprocessor board issue but can be something as simple as a loose or broken wire.
If it is in fact new you should contact Whirlpool for warranty service. Anything you would do as a consumer will void the warranty. First make sure your microwave is registerd via this link where it says "Register your product" http://www.whirlpool.com/custserv/index.jsp
Then using that same link you can schedule service or find out where your nearest carry in service center is.
Online Service Scheduling:
https://www.whirlpool.com/service/error.jsp?country=US&lang=en&brand=WP
CONTACT WHIRLPOOL
(866) 698-2538
Mon-Fri: 8am - 10pm (EDT)
Sat: 12pm - 5pm (EDT)
email: http://www.whirlpool.com/custserv/email_form.jsp
If the unit is second hand or out of warranty please include the model number in your next response.
Thanks for choosing FixYa,
Kelly
Dec 21, 2010 | Whirlpool Microwave Ovens
What does error code F7 on our Whirlpool g2microven mean?
Hi rongoin,
This error occurred if you have a stuck function key on ERC. This can only be resolved if you will replace control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Dec 11, 2010 | Whirlpool GH6178XPQ 1100 Watts Microwave...
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
Jul 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Nov 26, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
52 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
