Question about Craig Tower Speaker System For iPod, iPhone, iPad - CHT910
How do i connect to aux - Craig Tower Speaker System For iPod, iPhone, iPad - CHT910
Where do i connect the aux cable?
does your boombox have an aux output it should be 1 x red and 1 x white socket
Aug 07, 2012 | Starlite Nextplay Glitz and Glitter...
Don't know how to use aux option in 08 s550 ME Benz
First, you should locate the aux button or touch screen display for the aux and press it. If it reads no aux available or something similar then your model has the button but not the aux input itself. If it reads not connected, look for the aux port (looks like a headphone jack) in the center console region. after plugging in your device, simply hit aux and enjoy!
May 02, 2011 | Car Audio & Video
HOW TO USE AUX
AUX is the auxillary terminal to connect any input to the set. You must connect to the AUX input an IPOD or any device , use the conttrol panel to switch o the AUX and play the source.
Oct 28, 2010 | Sony CDX-F5510 CD Player
How do i get my aux working
connect the source of the device to the AUX and selct the AuX input so that the amplifier switches to play .
You must select AUX, connect audio out L&R of teh device ( ipod)to the input .
Sep 15, 2010 | Car Audio & Video
Can you connect two Bose Wave radios together for more sound volume?
There are several types of Bose Wave Radios - the one pictured (the others likely do, too) have "Line Out" and "Aux In" jacks. Each consists of a Left and Right pair of RCA type jacks. Simply connect the "Line Out" jacks of one of the radios to the "Aux In" jacks of the other. Select the "Aux" source of the radio that has the cable connected to the Aux In jacks. Whatever is playing on the main radio (CD, Tuner, or other input) will be heard on the second radio - if the Aux source is selected.
Please rate this reply if it was found to be helpful - good luck!
Jul 03, 2010 | Bose Wave Radio
I cannot figure out how to change my aux settings to on. Nor the d-aux. any help? I am also unable to change the display color.
try this
Setting the AUX Mode (V-Link)
AUX IN ON / AUX IN OFF (Initial setting)
You can input TV/video sound by connecting an optional Ai-NET/
RCA Interface cable (KCA-121B) or Versatile Link Terminal (KCA-
410C) to this component.
You can change the AUX name display when AUX ON is set. Select
the AUX name by pressing g or f. Then press BAND.
If the KCA-410C is connected, it is possible to select two AUX
names.
• Via KCA-410C, up to 2 external devices with RCA output can be
connected. In this case, press SOURCE/POWER to select AUX
mode and then press BAND to select your desired device.
Jan 28, 2010 | Alpine CDA-9847 CD Player
Connecting to the AUX input. Hard and software
you are connecting a cd PLAYER to an AMPLIFIER of some sort?
The rear connecters are audio/video out (red/white audio L/R and yellow is video) i assume rca connectors (phono)
The sound should be on for those connectors all the time, so no need to switch to audio out.
You connect to Aux in on the amp. and select Aux on that (amp meaning amplifier or stereo unit with aux in)
I hope this helps.
May 09, 2009 | Kenwood KDC-W5534U CD Player
Aux
there is an interconnector to connect this unit to the aux source (CD-RB20/CD-RB10)(sold seperately).
After connecting, press SOURCE until AUX appears in the display.
Press "play" on your ipod.
i sincerely hope this answers your question.
Jul 18, 2008 | Pioneer DEH-P80MP CD Player
AUX slots
hello..i think that.aux in this case is an output..you can try this through connecting your amplifier to any of the aux outputs... and play a cd ,sorry..good luck ..Ron.
Mar 07, 2008 | Kenwood KDC-MP235 CD Player
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Craig Tower Speaker System For iPod, iPhone, iPad - CHT910 Logo
Top Craig Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Steve F
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
