A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem" etc.) typically indicates the internal micro-electronics
of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire
runs at rear and lower side of the ink cartridge are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on all models which use HP 901 cartridges. Refer to
Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer
Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts -
Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers
Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500
J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP
901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
