I have a sony Bravia LDL 50r550a and sony 650 sound bar, I would like to listen to TV and be able listen to music on sound bar via bluetooth
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 1121 Answers
SOURCE: Need to get sound for wii w/ sony bravia tv and sound system
you must use a tv headsets jack or on wii output (RCA Connectors red/white) or Fibre Cable Wii output
Posted on Nov 29, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 6 Answers
SOURCE: My Sony KDL40XBR4 Bravia TV sounds keeps cutting in and out
Sounds like you have a bad Y sustain board, But if you want to part it out, I will by the screen from you and can offer $200 Dollars
E-mail me helpmycomputerfast yahoo com
Just add the at sign
Posted on Mar 16, 2010
Bravia hdmi hdtv lcd
It will be so. When you insert the headphone pin into its socket, the internal speaker connection will be automatically cut off, and you can listen the sound via the headphone only.
Sep 28, 2013 | Sony KDL40EX600 TV
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Unable to receive via bluetooth
Hi buddy,
Please check wheather ur memory is free or not then try to take the files from bluetooth.
Check both phone memory and memory card memory
Jul 29, 2009 | Nokia N90 Cellular Phone
I cannot bluetooth my contacts from my old sony ericsson 850i to my new blackberry 8320 even tho i have paired them,help please D.
unfortunately you cannot send address contacts via bluetooth with the blackberry.
you can send media files
go to the media folder you want to receive into and click the menu button and select "receive via bluetooth." Then send the file from the other phone. You have to do this for each file you send.
Good Luck and thanks for using FixYa
Jun 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
Bluetooth hansfree connection
hi splash,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Oct 30, 2008 | Samsung WEP200 Headset
Sony Ericsson P900 bluetooth music
hi friends hare solution http://www.mobilewo.com/viewtopic.php?f=40&t=65
Aug 17, 2008 | Sony Ericsson P900
Sony erricson k800 cant recieve files via bluetooth although i can send via bluetooth.
Did you turn the bluetooth on and put the phone in discovery mode before attempting to receive something via bluetooth?
May 01, 2008 | Cell Phones
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Bluetooth streaming audio?
only if it is the Stereo BT headset not a normal Bt headset will play music just allow you to make and receive calls
Oct 28, 2007 | Sony Ericsson W800i Cellular Phone
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
